In Memory of Member 1338
Results 1 to 10 of 10
Thread: Hawk HPS 5.0 Pads and Centric Cryo High Carbon Plain Rotors - What could go wrong?
  1. #1
    Registered Member
    2012 Mazda 5 GT, 2015 Mazda 3 5dr S GT Man
    Join Date
    Mar 2017
    Location
    CT
    Posts
    5
    So I set out to replace the front Rotors and Pads in my 2012 Mazda 5. While I am no professional mechanic I have done my share of work on cars. I used to Auto X and Road race a 1985 Pontiac Fiero and had replaced pads and rotors, sway bars, eurothane suspension bushings, Koni's and lowered springs, etc etc etc. After watching several you tube video's on replacing 2012 Mazda 5 rotors and pads and feeling very confident in my ability to retain a few hundred dollars in my wallet and improve my braking performance. I ordered Rotors and Pads from TireRack.com. While waiting my delivery, I went about my garage to make sure I had everything ready. Compressor - Check. Air Gun - Check. Jack and Stands - Check. Brake Cleaner, C-Clamp, Brake Lube - Check, Check, Check, ETC, ETC.
    So the big day arrives. I flip on the compressor and my air hose (lousy orange plasticky P.O.S.) starts leaking faster than the compressor can handle. Not an auspicious start. So, I zip down to Lowes and get a proper Rubber air hose. I block the rear tires and jack up the front of the car and place the jackstands, remove the front tires and finally start on the brakes. 2 - 17 mm bolts and I have removed the front left caliper and placed on a tool box so it doesn't hang by the brake line. I pull off the retainer spring then compress the caliper. (Yes, I already removed the Brake Master Cylinder cap.) Then I pry out the inside brake pad. Now for the Rotor.... 2- 1/2 hours later, after beating, hammering, spraying with PB Blaster, going inside to watch youtube videos and scour the internet for knowledge on how to free the rotor from the hub I was able to persevere. Hurray! I cleaned and lubed up the pins then reinstalled them added the pads, added a new rotor that I sprayed and wiped with brake cleaner, bolted everything back together and repeated the process on the Passenger side.
    I followed the bedding procedure at directed by Hawk Pads. So far so good.
    The next day after the brakes warmed up... Good Lord am I driving an old school bus? The brake squeal was insanely load. The brakes worked fantastically, but OMG the brake squeal at low speeds was enough to make you want to volunteer for the upcoming Mars Space Mission. My children asked to be dropped off a block away from school.
    So back to the internet. Did I miss something? The pads and rotors looked perfect. So whats wrong? Well, I didn't lubricate the brakes pads Tab's. Hmmm. OK, bring out the jack and the stands, remove the tires, pull the front brakes, Lube everything! Except the rotor's and pad's surfaces.
    Yes, repeat the bedding routine. (Couldn't hurt) Everything is working perfectly, no noise, excellent pedal feel etc. Then it's back! The cacophony of the First rehearsal in Music Man! I don't get it. There is nothing left to check! Could the pads be bad?
    The brakes work beautifully well. I don't know what else to check about the noise. Any suggestions would be appreciated.
  2. #2
    Registered Member Silentnoise713's Avatar
    2008 Mazda5 Grand Touring; 2009 Honda Fit Sport/Nav MT
    Join Date
    May 2010
    Location
    PA
    Posts
    2,618
    Have same setup but sized for MS3. IIRC, the Hawks come with new shims pre-applied. Take off shims and apply a thin but full coverage of anti-squeal paste (ex. CRC disc quiet). This and a gradual break-in (not bedding) over the course of 200-300 miles will help to settle the caliper piston into the shims, into the pads. Let paste dry before you go driving. The stock ATE brakes are quite simple with not too many moving components. My philosophy is new rotors = time for new fluid; new pads = bleeding.
    Above assumes the caliper slider pins move smoothly, the pads retainer clips is holding steady, and the new rotors are turning true.
    Stuff for sale:
    YellowSpeed DPS Coilovers - cheap
    ^http://www.wingood.com/flagselect.asp
    My Thread
    ^http://www.mazdas247.com/forum/showt...oise713-Thread
  3. #3
    Registered Member
    2012 Mazda 5
    Join Date
    Apr 2013
    Location
    Vancouver
    Posts
    724
    Sounds strange. I got el'cheapo eBay set and no noise at all.
    Some pads are noisier then others.
  4. #4
    Registered Member
    Join Date
    Mar 2017
    Location
    CT
    Posts
    5
    Did your pads come with shims?
  5. #5
    Registered Member
    Join Date
    Mar 2017
    Location
    CT
    Posts
    5
    Update. About 500 Miles later. I am still having noise at low speed braking after the pads warm up. I was about to throw away the old pads when I noticed the pad shims on them. They appeared to be glued to the back of the pads. These did not come with the Hawk Pads. Old Brake Pads 2.JPGOld Brake Pads 3.JPGOld Brake Pads 1.JPG I took some pictures.
  6. #6
    Registered Member
    Join Date
    Mar 2017
    Location
    CT
    Posts
    5
    My new Hawk pads clearly did not come with shims. See Photo's. I have contacted TireRack (Where I bought them) and they confirmed that they are supposed to come with Shims attached.
    Finally getting to the bottom of my noise problems.
  7. #7
    Registered Member
    too numerous to name...
    Join Date
    Jun 2016
    Location
    California
    Posts
    35
    Did the shims help the noise issues any? I'm looking to upgrade my front pads and would like to get more bite but without too much shrieking.
    Ruby
  8. #8
    Registered Member
    2012 Mazda 5
    Join Date
    Apr 2013
    Location
    Vancouver
    Posts
    724
    What about going with high quality pads like Akebono: https://www.amazon.com/dp/B000EQ6FHC
    I have them on my other car and very happy with it.
    Planning on install once my current once need replacement (maybe 3-4 years)
  9. #9
    Registered Member
    MAZDA5 09 5spd
    Join Date
    Jul 2019
    Posts
    2
    Hawk HPS has great stopping power and keep going after braking over and over at high speeds. They are however known for putting out a lot of brake dust and making way too much noise.
  10. #10
    Join Date
    May 2010
    Location
    PA
    Posts
    2,618
    Quote Originally Posted by phreak074 View Post
    Sounds like you have race or aggressive pads. That is the byproduct of stopping; something has to give.
    Just to clarify, Hawk carries the HPS, HPS+, and HPS 5.0. The OP and I are referring to 5.0 "street" pads. I wouldn't say they make excessive brake dust but they do work best at temp. Great pads. PSA: the rear pads don't seat into the Mz5 bracket securely. Seems a little undersize leaving a slight bit of play. Should apply a dollop or two of anti-squeal or they clank.
Similar Threads
  1. Rotors and Hawk Racing Pads - No Longer Available
    By ajpags in forum Completed Transactions
    Last Post: 08-27-2015, 07:00 AM
  2. F/S: Brand New Centric Rotors and brake pads
    By TreFlip999 in forum Global
    Last Post: 09-25-2008, 07:35 PM
  3. Centric Rotors / Posi-Quiet pads problem
    By Erci in forum Protege5
    Last Post: 06-19-2007, 02:48 PM
  4. Replies: 39
    Last Post: 09-10-2004, 07:58 PM
  5. WTF? Hawk pads ruined rotors in 50miles.
    By Mike R in forum Mazda Protege
    Last Post: 08-14-2004, 10:39 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
