VersaTuner - tuning software for Mazdas
Results 1 to 2 of 2
Thread: 09 Mazda6 Oil consumption and burning
  1. #1
    Registered Member Keatonc's Avatar
    2001 Mazda Protege MP3
    Join Date
    Sep 2012
    Location
    United States
    Posts
    69
    Ok, so I tried my hardest to see if this was a fixed issue on here, and on google, but hadn't found anything. My mazda6 is losing about a quart a week, and puts out HUGE clouds on the highway (high rpm). The breather hose on the valve cover isn't fully connected, and not sure if that is the issue, or if the PCV/oil separator is bad. Next to the separator, the head is hairline-cracked leaking the oil. Obviously Im looking for the cheapest and most straightforward fix, just need to know which part to go for first. My guess would be the breather hose connection (should this rattle like the PCV valve?). Or go ahead and tear-down the intake and see if its the PCV issue. Or maybe even piston rings (looks like a salvaged engine was put in here). Im just shorthanded at college without a place to work on it and need to drive it to work and school everyday. Thanks in advance for the help.
  2. #2
    Registered Member
    2009 Mazda6 GS 2.5L MT
    Join Date
    Sep 2014
    Location
    NYC
    Posts
    6
    That hairline crack is most likely your culprit. If that is the only place your seeing an active leak on, the PCV could be a culprit as well, and wont hurt, and wont be too expensive to replace. If your looking for a really quick fix....i would assess the severity of the crack. MMMMAAAAYYYYBBBBEEEE its possible tack weld it, or maybe even JB weld the sucker. But a new head would probably ultimately fix the issue.
    Sent from my 6045O using Tapatalk
Similar Threads
  1. My oil consumption
    By erhayes in forum CX-5 Engine & Transmission
    Last Post: 11-25-2017, 11:47 PM
  2. oil consumption ?
    By joe944 in forum Protege5
    Last Post: 03-12-2013, 04:59 PM
  3. Adding Mazda6 Illuminated Door Sills to 2009 mazda6
    By RaVE_Noodles in forum Mazda6 Accessories & Appearance
    Last Post: 08-04-2009, 11:36 AM
  4. Oil Consumption
    By InlineTwin in forum Mazda6 Engine & Transmission
    Last Post: 12-14-2007, 11:13 AM
  5. A burning question...About Oil Burning
    By Mazdamia in forum Protege5
    Last Post: 12-20-2006, 04:47 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
