Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Diesel vs gas torque/mph graph
  1. #16
    Registered Member
    Mazda cx-5
    Join Date
    Feb 2017
    Location
    Fredericksburg va
    Posts
    41
    It's tough to say. When I'm driving gas engine cars and trucks any more I'm kinda let down compared to driving a Cummins powered truck. Depending on the torque available at highway speed it may surprise you. No I'm used to have 800lb of torque on hand and at highways speed there is no turbo lag so it builds boost and starts pulling pretty quick. If the cx5 diesel can match the passing g power of my work truck even at 4.5 tons and shaped like a brick then I will buy one as soon as I can.
    Sent from my SM-G930V using Tapatalk
  2. #17
    Registered Member finch204's Avatar
    2013 VRM Mazdaspeed3, 2016 Soul Red CX-5 GT
    Join Date
    Nov 2014
    Location
    Grand Prairie, TX
    Posts
    967
    Quote Originally Posted by MA2LA View Post
    How much horsepower does your Cummins powered truck make?
    Looking at the performance numbers for a BMW 328d, which was a long term car for Motor Trend, its 45-65 mph time is only 4.1 seconds. That's the same 45-65 mph time as a 2016 Mazda CX-5. For a car with 280 lb-ft of torque, I expected its acceleration to be faster honestly. This is what makes me think 175 hp on the CX-5 diesel might not be significantly fast enough for highway passing compared to the NA 2.5 engine.
    These are all just assumptions from me though. I will know for sure once I can test drive one.
  3. #18
    Registered Member
    Mazda cx-5
    Join Date
    Feb 2017
    Location
    Fredericksburg va
    Posts
    41
    The truck is 380hp I think but even my older 99 Dodge with 215hp and 430lb always did great on the highway. Of course it all depends on what some people consider hwy passing . I look at more the 60 to 80 run more than the 45 to 65. I need to look up the numbers on my trucks and my old cx7 that was alot of fun.
  4. #19
    Join Date
    Nov 2014
    Location
    Grand Prairie, TX
    Posts
    967
    Torque is great for city driving, horsepower is great for highway passing. If a car does mediocre in 45-65 mph, it will do the same or slightly worse at highway speeds (60-80 mph). Not to mention, because of gearing, cars will typically be making more torque when doing 45-65 mph passes vs 60-80 mph passes.
  5. #20
    Registered Member
    Mazda cx-5
    Join Date
    Feb 2017
    Location
    Fredericksburg va
    Posts
    41
    If that is the case then with full-size trucks it's almost completely backwards. They are quick in the city but the passing power from 60 on up is where they really shine because they are able to build the boost quick and stay on the power curve longer. Before I bought my 2014 I drove the same basic trucks , one with the 6.7 Cummins and the other with the 6.4 hemi, the hemi was a little peppier around town but on the highway the 6.7 was much stronger. Even in comparison with in the truck world. The Chevy and Ford's tend to be quicker in a drag from dead stop but on the highway the Dodge tended to perform better and it had the lower HP. I'm looking forward to driving one when the dealer gets one. The biggest thing will be how they program the trans to do it's job and that where manufacturers have gotten it wrong may time before.
  6. #21
    Join Date
    Nov 2014
    Location
    Grand Prairie, TX
    Posts
    967
    It all depends on where the torque is being generated in the RPM range. A flat torque curve all the way to redline means that in WOT situations, the vehicle will still feel really fast at high RPM. Considering one of your trucks has at least 200+ hp and at least 400 lb-ft of torque, I think it is enough to make it go fast at highway speeds when passing.
  7. #22
    Registered Member
    was 175ps sport manual, now 175ps Mazda CX-5 Auto AWD Sport Nav
    Join Date
    Oct 2012
    Location
    worksop Great Britain
    Posts
    2,068
    I don't think anyone will be disappointed with the CX-5 diesel.
    The performance is good, everything about the performance will put a smile on your face.
    The 150ps is the sweeter engine it revs without effort and has good performance, the 175ps is quicker but not by that much, in the UK both are rated the same on the government tests, not that means anything in the real world, but it worth noting.
    I tow a 1565kg caravan, and my next one due is 1636kg, and i expect it to tow with out effort, in fact I'm having the caravan plated to 1700kg.
Similar Threads
  1. Graph: mpg vs mph
    By cx-500 in forum CX-5 Engine & Transmission
    Last Post: 09-20-2017, 10:21 PM
  2. Graph: mpg vs mph
    Last Post: 01-31-2017, 08:25 PM
  3. 1.5 Liter SkyActiv Diesel 184 lb-ft Torque!
    By Antoine in forum Mazda2 Lounge
    Last Post: 06-12-2014, 01:50 AM
  4. my dyno graph and vid
    By Erv in forum Mazda2 Lounge
    Last Post: 06-07-2012, 10:26 AM
  5. Replies: 0
    Last Post: 09-25-2009, 05:02 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
