Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: So what happens if...
  1. #16
    Registered Member
    Donated: $5
    2014 CX-5 GT FWD, 2015 Mazda 3 Touring
    Join Date
    Apr 2013
    Location
    Texas
    Posts
    1,642
    Quote Originally Posted by shaendra View Post
    OK thanks. That's what I was wondering - still not clear on how the fob is triggered except through some kind of request from the ignition and doors (but then, wouldn't it need to be listening?).
    The fob responds to two kinds of signals. RF and magnetic. RF is used when exchanging code info to unlock doors or start the car. Magnetic is used as a proximity detection.
  2. #17
    Registered Member
    2017 SRC CX-5 GT + Premium
    Join Date
    Feb 2017
    Location
    Houston, TX
    Posts
    332
    Quote Originally Posted by craigo View Post
    Probably best to keep it away from a wallet/CCs, then!
  3. #18
    Registered Member
    Donated: $5
    Join Date
    Apr 2013
    Location
    Texas
    Posts
    1,642
    Hyundai has a good system description of how it works: http://www.hsguide.net/description_a...ation-515.html
    This is a typical smart key system.
  4. #19
    Registered Member
    Donated: $5
    Join Date
    Apr 2013
    Location
    Texas
    Posts
    1,642
    No worries. The fob only emits RF. It wakes up to low frequency magnetic fields. This keeps its activity range close to the car.
  5. #20
    Registered Member
    cx5
    Join Date
    Jan 2017
    Location
    ontario
    Posts
    10
    As an aside, check that both your mechanical keys work on your car. I decided to test mine, and one was clearly not for my car! (dealer made a new key, no questions asked).
  6. #21
    Registered Member ddtigger1's Avatar
    2016.5 Mazda CX 5 Grand Touring W/ Tech PKG
    Join Date
    Aug 2016
    Location
    Portland, Oregon
    Posts
    261
    This was done on YouTube... it will run until you turn off the car. Then obviously it will not restart...
  7. #22
    Registered Member
    1990 Eunos (Mazda) V-Special Roadster (sold), 2014 Mazda CX-5 Pr
    Join Date
    Feb 2017
    Location
    Hiroshima Japan
    Posts
    187
    For us, the big PITA with keyless is that my wife constantly leaves hers in her bag which she will occasionally leave in the car when we run errands - and then I can't get the car to lock - until she digs it out. The worst was when it first happened. I had picked her up at the airport, she had left the fob in one of her suitcases, we had to run to my in-laws for an emergency, so she stayed there with them and one of her suitcases, while my daughter and i made the 200+ km trip back to our house. Of course I had the other suitcase in the car with the fob. I thought the system was broken until we figured out that she'd left it in the suitcase that I had. Thankfully Japan is generally safe enough that my kid and I were able to leave the car unlocked at the rest areas.
  8. #23
    Registered Member
    CX5 2.5L AWD
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    5,336
    You're driving and toss your fob out the window?
    In some areas littering carries up to a $10,000 fine.
  9. #24
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    744
    Isn't it kind of impossible to lock the car without the fob? I've been in a keyless ignition vehicle TWICE, so I am totally ignorant of this stuff.
    With our CX-5 the doors can be locked without the fob by using one of the two methods of locking the car from the inside. Either the electronic lock button that locks all the doors at once or the manual lock that only locks one door at a time. Lock the door(s) using one of those methods and then close the door.
    I found this out yesterday. If a fob is left inside of the car (inside my wife's purse for example and I have mine in my pocket) and I use the inside electronic switch to lock all the doors (they do lock) then close the door. All of the doors unlock at once and I get a series of warning beeps. Now, if I do the exact same thing but I use the lock button on the outside door handle. I still get the series of warning beeps but all the doors lock. The manual explains this but it makes no sense to me.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
  10. #25
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    744
    Are you sure that it's magnetic and not short range RFID?
  11. #26
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,095
    Arrow So what happens if...
    Quote Originally Posted by Conrad 16.5 View Post
    I agree with you. It should be short range RFID, not magnetic.
  12. #27
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    3,307
    Quote Originally Posted by Mattyredsox View Post
    There aren't a whole lot of thieves roaming rest areas in the US either.
  13. #28
    Registered Member
    Donated: $5
    Join Date
    Apr 2013
    Location
    Texas
    Posts
    1,642
    For communication with the SMART KEY FOB, SMK ECU generates a request (challenge) as an encoded and modulated 125 kHz signal at the inductive antenna outputs and receives the SMART KEY FOB’s response via the external RF receiver.
    The LF antenna amplifier/driver generates a 125 kHz sinusoidal carrier signal which is distributed to the different antennas.
    This document describes the LF as magnetic: http://www.atmel.com/Images/Article_...rivers-Key.pdf Presumably this is good for security as magnetic fields fall off quickly.
    Of course, implementations may vary.
  14. #29
    Registered Member
    2017 Mazda CX-5 GT
    Join Date
    Mar 2016
    Location
    Minneapolis, MN
    Posts
    84
    Any thoughts on the reprogramming of a 2016 Mazda3 keyless fob to a 2017 CX-5? (Obviously the key won't work, and assuming they didn't do a redesign on the push button start mechanism) When I lost my car I kept one of the fobs for sentimental reasons. It would be nice if I could use the fob as a third.
  15. #30
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    3,307
    I would assume that would work?!?
    Sent from my XT1585 using Tapatalk
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
