CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 9 of 9
Thread: Coilover question... Damper hitting e-brake line
  1. #1
    Living the wagon life...
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    246
    Has anyone had any issues with the lower part of the damper (the actual shock) on their rear coilovers hitting the ebrake line? if so, how did you fix this to make them go lower?
    i just installed a set of Godspeed MonoSS coilovers over the weekend and ran into issues with the damper section hitting the ebrake assembly. had to raise the car as it was causing the pad to drag on the rotor.
    My 2003 Protege5 5spd aka "Battlewagon" build thread... CLICK HERE
  2. #2
    Registered Member ApolloP5's Avatar
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Colorado
    Posts
    28
    I have a set if Ksport coilovers on my P5 about 2 threads before the lowest setting and it doesn't hit. But then again maybe the sedan might have different routing of the Ebrake line.
    Sent from my LG-K540 using Tapatalk
    Zoom Zoom!
  3. #3
    Team Pro5 Jackie chan's Avatar
    Pro5
    Join Date
    Mar 2011
    Location
    Seattle, WA
    Posts
    1,889
    I had issues with my yellowspeeds doing this. I got longer bolts for the ebrake brackets, spaced the cable out around the shock with some washers, and adjusted the ebrake. Huge pain.
    Sent from my SM-G900T using Tapatalk
  4. #4
    Mazda Protege5
    Join Date
    Apr 2016
    Location
    Colorado
    Posts
    28
    Quote Originally Posted by Jackie chan View Post
    That works too.
  5. #5
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    246
    sounds like an interesting idea... ill have to take a look.
    i dont suppose you can yank one of your wheels and take a picture of your setup?
  6. #6
    Pro5
    Join Date
    Mar 2011
    Location
    Seattle, WA
    Posts
    1,889
    Yeah, after work.
  7. #7
    Pro5
    Join Date
    Mar 2011
    Location
    Seattle, WA
    Posts
    1,889
    Quote Originally Posted by dorkidori_s13 View Post
    Sorry for the delay. Here are some pics.
    You have to remove the cable holder from the trailing arm and mount it on just one stud. This gains you some slack, then get longer bolts and space out the brackets.
    Hopefully you can grasp what's going on in the pics.
  8. #8
    2003 Mazda Protege5
    Join Date
    Feb 2011
    Location
    Las Vegas, NV
    Posts
    246
    ill have to pull the wheel and take a look now that you posted some pics. im not 100% sure what youve got going on, but i think ill understand it a lot more if i compare your pics on my phone to exactly how the bracket is bolted on with my head in the fender well
    thank you for the photos
  9. #9
    '03 P5 OG owner Blue Pro5's Avatar
    Mazda Protege5
    Join Date
    Jan 2017
    Location
    So Cal
    Posts
    45
    Marked for reference.
Similar Threads
  1. Relentless tire noise when hitting brake
    By drewjonn in forum CX-5 Wheels, Tires, Brakes & Suspension
    Last Post: 08-09-2016, 02:14 PM
  2. Brake line/clutch line
    By InspirenNick in forum Mazdaspeed Protege
    Last Post: 12-12-2013, 11:03 PM
  3. Hardpipes Hitting Brake Fluid Reservoir
    By HFD45 in forum Mazdaspeed Protege
    Last Post: 02-17-2006, 08:03 PM
  4. Stainless brake lines hitting crossmember, how to fix?
    By MazdaNeal in forum Mazda Protege
    Last Post: 05-16-2005, 11:44 PM
  5. AEM intake hitting Brake Master Cylinder: help!
    By Pretzellogic in forum Mazda Protege
    Last Post: 04-22-2004, 10:26 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
