2016 CX-9 jacking points?
shjin404
2016 Mazda CX-9 Signature
Does anyone have a service manual or diagram showing jacking points for 2016 CX-9?
I plan to change oil soon and want to know where I can place the floor jack. This video shows he didn't find any center jacking point, but I am guessing it should be there.
Ramps work well for an oil change. There is a small plastic panel to remove, then the drain is easy to access.
The picture link is broken. Can someone provide a new link and a description of the center jack points?
Thanks, that clears things up. Here is a quick summary in case links break in the future: So the front center jack point is the dimpled plate just behind the plastic engine tray. The rear center jack point is a tab that sticks out from the cross member of a fwd or part of the rear diff on awd.
