Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Need help with "End of life" decision - Transfer Case + Transmission 08 CX-9 AWD
  1. #16
    Registered Member
    Join Date
    Oct 2013
    Location
    trois-rivieres
    Posts
    65
    a bunch of ford with the same transfer case have the transfer case breaking too but they don't break the transmission with it, the transmission splines problem is only on the cx9 i beleive
  2. #17
    Registered Member
    92 MX-3; 18 CX-5
    Join Date
    Jan 2019
    Location
    MN
    Posts
    49
    Quote Originally Posted by puma View Post
    The transmissions, PTU and location of the PTU with exposure to high heat and quick break down of the gear oil are all the same.
    Quote Originally Posted by kornholio View Post
    I totally agree with the above poster. I am curious as to why i don't hear about the ford explorers 2011-present having transfer case problems. I hear about the water pump with both the cx-9 and the explorer but only the mazda cx-9 has the failed transfer case/ trans problem. Please remember that the parts of this vehicle were built by ford but designed by mazda.
    I disagree - and agree with puma: All PTUs shared by many Ford vehicles and the CX-9 suffer same failure rate. I do believe most can be avoided with frequent PTU gear oil changes - but Mazda and Ford until recently recommended no PTU gear oil changes. And, to be fair, it is not an easy job.
  3. #18
    Registered Member
    Mazda CX-9 GS AWD
    Join Date
    Oct 2017
    Location
    Ontario
    Posts
    7
    At the same point now. I have had the transfer case replaced 3 times (under extended warranty) and now the 4th one has just failed. Back to Front wheel drive car only. I have exhaust leaks and a CEL for code P0016 (camshaft position sensor). I think its just a bad sensor though.
    Has anyone found a source for re-manufactured transfer cases? I would put a few hundred $$ into replacement if it gets me through another winter.
  4. #19
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,226
    Lkq.online (they also sell on ebay).. the dealer will always rape on parts, typically because they only buy new. Independent shop.
Similar Threads
  1. 2008 CX-9 Transfer Case/Transmission follow-up after fixing
    By jcardona in forum CX-9 Engine & Transmission
    Last Post: 01-19-2017, 10:03 PM
  2. 2008 transmission fluid and transfer case
    By bobbyseal in forum CX-9 Engine & Transmission
    Last Post: 10-20-2016, 12:50 PM
  3. New Engine, Transmission, Timing Chain and Transfer case
    By Mwith6 in forum CX-9 Engine & Transmission
    Last Post: 08-17-2016, 10:44 AM
  4. FS: MS6 Transmission & Transfer Case
    By nattun in forum Mazda6 For Sale
    Last Post: 02-19-2013, 06:30 PM
  5. Transmission and Transfer Case Oil change
    By needforspeed6 in forum Mazda6 Engine & Transmission
    Last Post: 01-19-2011, 05:07 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
