It's possible, but probably not. Your EGR could be dirty, your MAF could be dirty or failing, you could have a bad coilpack or wire, or your plugs may need to be replaced. Could even be a dirty or bad primary O2 sensor. I would start there and then reset the battery and see if it improves. Also check the accordion tube for tears if you have the stock intake.
