Will likely part out the AWR mounts.
Rear was unused
More like never installed...
Those rear mounts are a PITA. Lol
Rear was unused
try filling your original mounts with 3m windo weld. worked out good for my p5. eliminates the engine slop and doesn't make the car vibrate everything off.
I had a pal recently recommend this to me. He and his dad before him did it to their muscle cars, and says it did the job without buzzing the interior panels off. I might give it a try...20 bucks a can beats saving up for a 400+ dollar mount kit
Just OEM mounts. We'll see how they hold!
I have to check. Not sure if it was from when I installed the coolant overflow or if the hose isn't tight etc.
The radiator isnt' even a year old so hoping it's not that.
Although I may have to look into that radiator cap suggestion.. used the Mishimoto one that came with it but read it sometimes leaks.
How did you clean it up? Just simple green or something?
... Need to remove the bolt in the middle. Then you'll see the mount bolts..
