2007 transmission vs 2008+?
anyone knows if the transmission on the 3.5 in 2007 is the same or not to the 2008+ with the 3.7?
Basically, can i put a 3.7 transmission to my 3.5?
thanks
No.
"The 2008 CX-9 uses an Aisin F21++ six-speed automatic transmission with a console-mounted shifter in a complex gate."
It specifically mentions the 08- why would they do that if they were the same?
I have found nothing indicating they are the same, nor interchangeable through the channels I utilize every single day.
No.
I think its the same since the 3.5L Cyclone engine is the same engine as the 3.7L but it is just bored out a little. I doubt they would change the case castings or anything else. Another way to check is to call the dealer and price out a 2007 and 2008 transmission and compare the part numbers. If they are the same, then you are good to go.
