Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Is change oil necessary/recommended after break-in period?
  1. #1
    Registered Member
    2017 CX-9 Signature
    Join Date
    Feb 2015
    Location
    Canada
    Posts
    338
    Any suggestions/advise if necessary or recommended to change the oil after new vehicle's break-in period of 1000KMs? It doesn't state any such maintenance in the owner's manual of the new CX9 just some basic tips of no hard acceleration, no hard braking, not to travel for ext period of time at constant engine speed and not to over rev engine and no towing. Pretty sure modern engines require less maintenance these days compared to 20-30 yrs ago...
  2. #2
    Registered Member
    2017 Mazda CX-5 GT; 2017 Mazda MX-5 RF/GT/LE
    Join Date
    Jun 2016
    Location
    Austin, TX
    Posts
    213
    Officially, no early oil change is needed.
    Modern CNC machining and sonic cleaning result in tighter tolerances and less break-in wear.
    Furthermore, Mazda uses synthetic oil with a high moly content that minimizes engine wear.
    That said, I'm still "old school" enough that I have an early (1,000 miles or so) oil change performed on all of my new vehicles.
    It's likely a waste of $, but it satisfies my ocd tendencies when it comes to car maintenance.
    Bottom line ... early oil change is neither necessary nor recommended.
    OCD individuals like me do it anyway.
    2017 Soul Red Crystal Metallic CX-5 GT/Premium
    2017 Machine Gray Metallic MX-5-RF GT/MT, Launch Edition
    23 Mazdas since 1974
  3. #3
    Registered Member
    2016 Mazda CX9 Signature, 2013 Merc GLK350 4Matic, 2001 S2000
    Join Date
    Aug 2016
    Location
    Ontario
    Posts
    65
    Turborascal is correct. If you search on BITOG, there is no clear advantage either way.
    I am OCD as well and like the piece of mind of getting any break in particulate out of the engine ASAP (although its mostly captured by the filter).
    I have done this on all my vehicles.
    I did the oil and filter change on my CX-9 myself at 2000kms... Pennzoil Ultra Platinum 5W30 w/Mobil 1 EP Filter
    Do whatever makes you sleep at night
    Cheers
    Quote Originally Posted by Turborascal View Post
  4. #4
    Registered Member
    2017 CX-9 Signature
    Join Date
    Feb 2015
    Location
    Canada
    Posts
    338
    Does it state anywhere what brand/type of oil is used on the new CX9s? Is it really full synthetic 5W 30 grade? Just curious...
  5. #5
    Registered Member
    2013 CX-9 Grand Touring
    Join Date
    Sep 2013
    Location
    Burleson, TX
    Posts
    199
    Yes, the owners manual has all that info (except maybe brand).
  6. #6
    Registered Member
    2017 CX-9 Signature
    Join Date
    Feb 2015
    Location
    Canada
    Posts
    338
    Thanks for the input guys! Much appreciated...
  7. #7
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,281
    Arrow Is change oil necessary/recommended after break-in period?
    OCD or not but I have different opinion about changing oil too early on a brand new vehicle. On new CX-9 I'd suggest changing your oil at 5,000 miles for the first oil change, then follow the Schedule 1 Engine Oil Flexible Maintenance Interval by turn on your oil life monitor. The "Flexible" OCI calculates the oil life and display the "Oil change due" message when the oil change is due. For CX-9 the maximum Flexible OCI can be up to 12 months or 7,500 miles. You can change your oil earlier before your oil life dropped to very low percentage if you feel like it, just remember to reset it via Maintenance Monitor to make the oil life monitor in sync with fresh oil after you changed the oil.
    It's proven by UOA on CX-5 that the factory filled oil in SkyActiv-G has very high level of molybdenum compounds which not only provide frictional benefits, but also have been shown to decrease LSPI, Low Speed Pre-Ignition. LSPI can cause engine damage and it could happen to GDI engines like SkyActiv-G. For CX-5 we can get Mazda 0W-20 Moly oil and by changing factory fill early with it should not lose too much moly. But CX-9's SA-G turbo calls for 5W-30, and finding 5W-30 with high moly content is not an easy task. That's why I strongly suggest to leave your factory filled oil there as long as possible for your new CX-9, and try to find high-moly 5W-30 oil and use it afterwards. Mobil 1 contains high calcium which actually promotes LSPI. See more discussions here:
    2.5L Oil level fluctuation
    Although Mazda doesn't say it, but Honda has specifically said in the break-in section of owner's manual that don't change oil early as they use special "break-in" oil for factory fill.
    So my bottom line ⋯ early oil change is neither necessary nor recommended. This includes OCD individuals like me!
  8. #8
    Registered Member
    2017 CX-9 Signature
    Join Date
    Feb 2015
    Location
    Canada
    Posts
    338
    Quote Originally Posted by yrwei52 View Post
    Thank you for the wonderful insights! I normally use castrol edge full synthetic on my volvo for 7yrs and no issues. Mazda recommends castrol as well...would castrol edge full synth 5w30 be a good oil for CX9? Btw, our scheduled maintenance here in Cda is the sched2 and not 1....
  9. #9
    Registered Member
    Mazda CX9 2016 GT AWD
    Join Date
    Feb 2011
    Location
    Mexico City
    Posts
    478
    When I purchased my GT AWD CX9 in june 2016 I setup the oil change reminder to 5000 km. Now in a long trip I reach 5500 km and get the oil change alert. How I can remove it? According to this post (and to the dealer), the oil change needs to be done at 10,000 km. I expect to reach such numbers in about 5 or 6 months.
    I cannot delete the message!
  10. #10
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,281
    Quote Originally Posted by tekbis View Post
    Yeah for some reason Mazda doesn't allow Canadian to use excellent oil life monitor to maximize the oil life and reduce the oil waste. Molybdenum is added for better lubrication and now also been proven to reduce LSPI. IMHO I'd use any 5W-30 full synthetic oil with high molybdenum content. Unfortunately many oil companies don't mention it and we can only rely on UOA to find out most of them. Red Line oil has been known with high molybdenum content and there're some others:
    The most oil with most moly in it? 0w20 and 0/5w30
  11. #11
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,281
    Arrow Maintenance Monitor
    Quote Originally Posted by cubanomx View Post
    As I mentioned earlier, you should use Schedule 1 Engine Oil Flexible Maintenance Interval by turn on your oil life monitor. The "Flexible" OCI calculates the oil life and display the "Oil change due" message when the oil change is due. For CX-9 the maximum Flexible OCI can be up to 12 months or 7,500 miles. You can change your oil earlier before your oil life dropped to very low percentage if you feel like it, just remember to reset it with "Flexible" via Maintenance Monitor (ignition on、don't start the engine) to make the oil life monitor in sync with fresh oil after you changed the oil. Once you did the reset, the warning message for maintenance will be gone.
  12. #12
    Registered Member
    Join Date
    Feb 2011
    Location
    Mexico City
    Posts
    478
    I still have the change oil message in my display. Very annoying!.
    Enviado desde mi Samsung Galaxy S7 Edge.
  13. #13
    Registered Member
    Join Date
    Feb 2011
    Location
    Mexico City
    Posts
    478
    Any idea about how to remove the oil change message from the display. This is crazy!
  14. #14
    Registered Member ManUtd's Avatar
    2016 CX-9 Signature
    Join Date
    Dec 2016
    Location
    San Jose, CA
    Posts
    29
    I just read in the manual that "flexible setting" is only for the US and Puerto Rico. Seeing that you're in Mexico your only options are "fixed setting" or "off setting below". Have you tried this reset method?
  15. #15
    Registered Member
    2016 CX-9 Signature, 1992 Miata
    Join Date
    Dec 2016
    Location
    Maryland
    Posts
    22
    Quote Originally Posted by ManUtd View Post
    Starting with version 59, the method is obsolete, you now need to reset the oil setting in the maintenance section of the infotainment system.
    http://infotainment.mazdahandsfree.c...language=en-CA
    Estas instrucciones ya no funcionan, tienes que reiniciar el sistema usado el menú de mantenimiento en en configuraciones.
Similar Threads
  1. Break in period?
    By JTNY in forum CX-5 Lounge
    Last Post: 06-01-2012, 05:15 PM
  2. MS3 Break-in period
    By Jasonstiller in forum Mazdaspeed3
    Last Post: 04-05-2007, 02:14 AM
  3. Break-in period...
    By WalksInDarkness in forum Mazdaspeed3
    Last Post: 04-04-2005, 09:04 PM
  4. Break in period?
    By SuperSpud in forum Mazdaspeed Protege
    Last Post: 06-15-2003, 03:05 PM
  5. Break-In period?
    By noway868 in forum Protege5
    Last Post: 07-05-2002, 08:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
