Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Battery drainage WTF?
  1. #16
    Registered Member
    2013 CX5 Sport
    Join Date
    Jan 2017
    Location
    Long Beach
    Posts
    5
    Quote Originally Posted by yrwei52 View Post
    From PepBoys?
    Yeppers.
  2. #17
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,397
    Mine did not start even with the negative to the metal surface.
    I had to charge it and only then it started. Today worked like nothing happened.
    This is the third time, since new(3.2 years/25k miles). I can't explain it.
  3. #18
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,373
    Yep, negative clamp should be connected to engine bare metal on the dead vehicle, not to negative post of the dead battery.
    Quote Originally Posted by tibimakai View Post
    Was able to jump start the car successfully via the black negative cable connected to battery. Follow its path away from the battery until you see the "exposed metal connection" it makes to the body on the strut tower area. Place clamp there.
  4. #19
    Join Date
    May 2013
    Location
    Posts
    2,397
    The CX5, cuts the power after a while, if left some light on, right?
  5. #20
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    935
    Early models do not, 2016 does for some but not all. I find it easy to bump the interior light switch when putting away my sunglasses and I believe it will stay on until turned off...
  6. #21
    Join Date
    May 2013
    Location
    Posts
    2,397
    Bad battery, confirmed by Autozone tester. Got a new battery from Costco, for $78 after core($15). 640CCA/48 months warranty/Interstate.
  7. #22
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,535
  8. #23
    Join Date
    May 2013
    Location
    Posts
    2,397
    You need that, if you store your car.
  9. #24
    Registered Member
    Join Date
    Jun 2007
    Posts
    108
    Had an issue with my 2015 touring where it was slow cranking for the past 3 weeks or so, and yesterday it just clicked... Called the dealer after jumping it and getting home, was told that starting with the 2015 model, Mazda is warranting the battery in the CX-5 for the full 3/36 warranty period. I took it in today, they tested it, and replaced it free of charge... it cost me an hour of my time because I chose to wait.... Hats off to Mazda and the dealership on this one...
  10. #25
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,373
    Quote Originally Posted by Dmac43 View Post
    Considering you have a 2015 they could've covered it under the bumper-to-bumper warranty. Only thing I see regarding the battery is if you go to a Mazda dealership to have a new one installed- that new one is covered 100% for 3 years.
    1-36 months: Free replacement and labor
    37-48 months: Customer is responsible for 70% of the battery MSRP and labor
    49-60 months: Customer is responsible for 80% of the battery MSRP and labor
    https://www.mazdausa.com/owners/warranty
    Interestingly enough, Mazda dealer installed brake pads are covered with a lifetime warranty. So if its below spec 30k miles later or so I guess they are replaced with free pads with warranty and you pay for labor.
  11. #26
    Registered Member
    2015 CX-5 touring
    Join Date
    Feb 2013
    Location
    SWFL
    Posts
    31
    Costco didn't have the right battery for my cx-5 wtf!!?!
    Sent from my iPhone using Tapatalk
  12. #27
    Join Date
    May 2013
    Location
    Posts
    2,397
    Sorry about that.
  13. #28
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    759
    Quote Originally Posted by Chris_Top_Her View Post
    I personally wouldn't use a $7 battery tender/charger on my car, you get what you pay for.
    Here's what I've been using for years on my motorcycle, truck, motorhome, and cars.
    https://smile.amazon.com/Deltran-Bat...ry+tender+plus
    https://smile.amazon.com/Battery-Ten...ry+tender+plus
    Check out the ratings at Amazon on those two.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
Similar Threads
  1. coolant drainage
    By Pmazda5 in forum Protege5
    Last Post: 07-28-2015, 07:22 PM
  2. Rear hatch water drainage holes
    By piancu in forum CX-5 Lounge
    Last Post: 12-29-2014, 05:15 PM
  3. 130ma battery drainage - help
    By Typhoonk123456 in forum Mazda5 Infotainment
    Last Post: 12-19-2014, 07:56 PM
  4. Typical battery drainage?
    By Tzar177 in forum Mazdaspeed Protege
    Last Post: 01-05-2012, 12:03 PM
  5. Masochistic dealer anal raped up my oil pan drainage bolt
    By solid_snake in forum Other Mazdas
    Last Post: 10-13-2005, 06:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
