Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Battery drainage WTF?
  1. #1
    Registered Member
    2013 CX5 Sport
    Join Date
    Jan 2017
    Location
    Long Beach
    Posts
    5
    Howdy y'all. My wife has a 2013 CX5. It still had the original Panasonic battery with about 55 months on it. Cranking was weak and she was told on her last couple of oil changes that the CCA was low so I figured it was time for battery.
    I put in the new battery and it seemed hunky dory. Started right up. That was Friday. She drove it Saturday and parked it for the weekend. Tuesday morning she tried to start... no go. What the hell?
    I tried it again later and it cranked over but was very weak. So I let it run a bit in the driveway and it charged up enough to let me do some experimenting.
    I went and ran an errand, basically a 1 hour round trip drive without using lights except daytime runners and no radio, fan, heat, etc.
    After geting home, turned the car off, voltage at 12.65
    Waited 15 minutes and checked again, voltage at 10.65
    Left car off a bit longer and checked again, at 10.65
    Started car, dropped to < 8v for a sec and then kicked up to 13.70
    Ran engine at 1500-2000 rpm for 10 minutes with lights, defroster and fan all on at different times. Voltage dipped briefly to as low 13.1v when defroster turned but stayed at 13.7v until car warmed up and then started falling slowly to 13.1v
    Turned car off and voltage fell to 10.9 within a minute.
    Checked after 5 minutes, at 11.6v
    Checked 20 minutes later, back up to 12.0v
    WTF? When the battery had enough charge, the starter and engine kicked right over. The alternator must be charging it but the battery won't hold a charge. Bad regulator? I didn't test it before i put it in but maybe it's bum battery?
    FWIW, I'm in SoCal. It hasn't been much below 50, maybe 45 at the lowest lately.
    Thanks for any ideas on this one.
  2. #2
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    977
    What kind of battery? Are you able to pop off the top caps and see if you actually have enough fluid in it? The old battery didn't give you this many problems so maybe you need to put it on a charger. Yeah, I know it's new, maybe it's just bad.
  3. #3
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,288
    Arrow Battery drainage WTF?
    If your 55 month old OE Panasonic battery didn't have similar symptoms and was still able to start up, and you're sure all the connections at battery posts are clean and tight, I'd say your new battery is the culprit. I know it's a hassle but you may have to take the new battery back and try another one. Yeah it happens. BTW, what kind of battery is it?
  4. #4
    Registered Member
    2013 CX5 Sport
    Join Date
    Jan 2017
    Location
    Long Beach
    Posts
    5
    It's a Bosch premium Power. I didn't even consider checking the fill level or the charge. I've never had one bad right out of the gate.
    Posts and everything else is pretty damn clean. I'll just take it back and see what happens with a another one.
  5. #5
    Registered Member Bcdad182's Avatar
    2013 CX5-GS, AWD
    Join Date
    Jul 2012
    Location
    BC, Canada
    Posts
    282
    Check my thread on this, post #6 has a link to a TSB -- since yours is a 2013 as well, its entirely possible its a bad connection as mentioned in the TSB. Mine exhibited as a draw on a brand new battery and started to cause all kinds of issues with door locks, communications between the various modules and the security system. The mechanic temporarily fixed it by cleaning the connectors, and I'm taking it back soon to get the new harness installed for a hopefully more permanent fix.
    https://www.mazdas247.com/forum/show...le-Immobilized
  6. #6
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,227
    Spent over 5 years in the Automotive stores, bad batteries from new purchase can and do happen...
    From the battery assembly line to the final resting spot in your vehicle, there are lots of miles of travel and loading/unloading handling.
    The ~10volt readings you get are what make me feel it might have a bad cell.
    But if indeed it is a new defective battery, go get yourself a lotto ticket too!
    Mazda's I have owned over the years.
    80' Mazda GLC SPORT MT - sold
    81' Mazda 626 DX MT - sold
    81' Mazda 626 LX AT - sold
    82' Mazda 626 DX MT - sold
    82' Mazda 626 LX AT - sold
    85' Mazda 626 LX MT - sold
    87' Mazda 626 GT Turbo MT - sold
    85' Mazda RX-7 GSL-SE MT- sold
    87' Mazda RX-7 Turbo 2 MT - sold
    91' Mazda Protege LX MT - sold
    92' Mazda MX-5 Miata MT - sold
    93' Mazda MX-3 GS-V6 Special Edition MT - sold
    00' Mazda 626 LX-V6 MT - sold
    02.5' Mazda Protege5 MT - sold
    06' Mazda 5 Touring AT - sold
    13' Mazda CX-5 Touring AT - sold
    14' Mazda 3i Grand Touring MT - sold
    15' Mazda CX-5 Touring AWD AT - sold
    03' Mazda Protege5 AT - sold
    16.5' Mazda CX-5 Touring AWD AT - current
    09' Mazda Mazdaspeed3 GT - current
  7. #7
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,404
    My car, did not start today either. 3 years and two months old, with 23800 miles on it. Tried jumping with the charger on high amp, but did not turn fast enough, to start. Had to go to work, did not have time, to mess with it.
  8. #8
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,378
    Quote Originally Posted by tibimakai View Post
    Original Battery? Also did you place the negative jumper terminal on the location as referenced in the manual? I ask because I tried jumping the CX-5 last year when the battery died and could not...until I read the manual and noticed I was doing it wrong
  9. #9
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,288
    Quote Originally Posted by CX-5um View Post
    Yep, negative clamp should be connected to engine bare metal on the dead vehicle, not to negative post of the dead battery.
  10. #10
    Join Date
    May 2013
    Location
    Posts
    2,404
    I did it wrong then. Thanks for pointing that out. I will try it soon, that way.
    I will also measure the parasitic voltage drain, when the car is turned off.
    The battery, is still the original. There is not much cold in LA, so I don't think that the cold can be a cause.
  11. #11
    Registered Member
    2013 CX5 Sport
    Join Date
    Jan 2017
    Location
    Long Beach
    Posts
    5
    Quote Originally Posted by mazdadude View Post
    Bingo! Looks like you win.
    I took it back to the parts store and they suggested doing a charging system inspection for $17. I said "what if it just turns out to be the battery?" and the guy said, "Well we have to charge."
    When they told me it was the battery and asked for $17 I basically said so you sold me a bad battery and wanna charge me for finding a problem with your product? I got the charge waived.
    30 years of buying batteries... now I know to check it before I even install it.
  12. #12
    Registered Member
    2013 CX5 Sport
    Join Date
    Jan 2017
    Location
    Long Beach
    Posts
    5
    Lotto ticket tomorrow!
  13. #13
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,227
    Quote Originally Posted by puckhead95 View Post
    Glad it is fixed!
    Good luck!
  14. #14
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,288
    From PepBoys? And they want $17 for charging system inspection? Bosch should be a good name from Europe but some US battery manufacture made it for them here.
    At least you don't have to worry about your battery for another 3~4 years!
  15. #15
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,378
    Good to know...to check the battery before it gets put on your car. May have to bring my multimeter with me when shopping batteries.
Similar Threads
  1. coolant drainage
    By Pmazda5 in forum Protege5
    Last Post: 07-28-2015, 07:22 PM
  2. Rear hatch water drainage holes
    By piancu in forum CX-5 Lounge
    Last Post: 12-29-2014, 05:15 PM
  3. 130ma battery drainage - help
    By Typhoonk123456 in forum Mazda5 Infotainment
    Last Post: 12-19-2014, 07:56 PM
  4. Typical battery drainage?
    By Tzar177 in forum Mazdaspeed Protege
    Last Post: 01-05-2012, 12:03 PM
  5. Masochistic dealer anal raped up my oil pan drainage bolt
    By solid_snake in forum Other Mazdas
    Last Post: 10-13-2005, 06:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
