Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: 2016 Mazda CX-9 Wheel Vibration
  1. #16
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    2,048
    I hope that fixes it! That is crazy. Just had my 08 aligned and balanced, still rides smooth as ice on the interstate.
  2. #17
    Registered Member
    Join Date
    Nov 2006
    Location
    PA
    Posts
    252
    Update:
    The dealer had my car while I was on vacation. They replaced all 4 tires and replaced the drive shaft propeller.
    So far, so good. Hopefully the issue has been corrected.
    My dealer has been extremely helpful during the process.
  3. #18
    Registered Member
    Mazda CX-9 Grand Touring 2016
    Join Date
    Sep 2016
    Location
    Washington, the state
    Posts
    239
    Propeller shaft = drive shaft. An unbalanced drive shaft can be a hard-to-find source of vibration. If they did tires and drive shaft, then they didn't know where the problem was and just did everything.
  4. #19
    Registered Member
    Join Date
    Nov 2006
    Location
    PA
    Posts
    252
    Quote Originally Posted by PTguy View Post
    Vibration is back, so the drive shaft nor the tires are the culprit. Waiting for further diagnosis. Not feeling very confident at this point.
  5. #20
    Registered Member
    2013 CX-9 AWD, 2016.5 CX-5 AWD
    Join Date
    Oct 2015
    Location
    _
    Posts
    322
    Quote Originally Posted by Aviboy97 View Post
    did they look at the engine mounts ? sometimes they go bad or get loose and the engine will vibrate the car at highway speeds.....
  6. #21
    Registered Member
    Join Date
    Nov 2006
    Location
    PA
    Posts
    252
    Quote Originally Posted by batmancx View Post
    Not sure if they checked those. The problem is the vibration is intermittent. Doesn't happen all the time, and it's sometimes worse than other times. It's very frustrating.
    It feels like it's originating from the rear. I believe the next step might be to replace the rear diff to see if it's the cause.
    They replaced the drive shaft because they road tested the car with it taken out and it seemed to disappear. Logical thought process, but after a couple days, the vibration returned.
    This is the weirdest thing I've ever encountered with a vehicle.
  7. #22
    Registered Member
    Mazda CX 9
    Join Date
    Nov 2017
    Location
    Vaudreuil-Dorion, Québec, Canada
    Posts
    4
    My 2017 Signature experienced the exact same problem after 6000 Km and Mazda Dealer tried the same repairs you mentioned above. Vibrations are still present though.
    If the problem was solved on your car can you share the solutions please?
    Regards
  8. #23
    Registered Member
    Mazda CX 9
    Join Date
    Nov 2017
    Location
    Posts
    4
    Quote Originally Posted by Sax barython View Post
    Regards
    Mazda dealer replaced my winter steel wheels with alloy wheels and vibrations stopped!
  9. #24
    Registered Member
    Join Date
    Sep 2016
    Location
    Posts
    239
    It is possible that the winter steel wheels were not actually centered when the tire shop balanced them by mounting them on the balancing machine using the wheels' center pilot hole. If the wheels had been balanced centered by the lug holes they might have been fine. The lug-centric adapter is not used as often as it should be used on certain wheels. With non-OE wheels, the center pilot hole is sometimes not in the actual true center of the wheel.
    If the vibration can be construed as diminishing use, value, or safety, look into your state's Lemon Law--each state is a bit different. Canada has a weaker system, but also worth looking into. A Lemon Law filing gets the manufacturer's attention better than a complaint from any of us.
Similar Threads
  1. 2016 cx-9 grand touring highway speed vibration
    By hancockjames in forum CX-9 Lounge
    Last Post: 05-18-2017, 12:40 AM
  2. 2.0 Manual 2016 Vibration through Pedals Normal?
    By silverevo05 in forum CX-5 Lounge
    Last Post: 01-02-2017, 04:15 PM
  3. 2016 CX-5 vibration/shaking when exiting left turn
    By helloworld in forum CX-5 Lounge
    Last Post: 06-03-2015, 11:21 PM
  4. Wheel Vibration
    By 5zoom in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 11-02-2009, 11:23 PM
  5. Wheel vibration
    By Artimus in forum Protege5
    Last Post: 03-28-2007, 07:43 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
