mikefly562
- 2016.5 Mazda CX-5 Grand Touring
I've been having connectivity issues with Pandora (using my iPhone 6s Plus and iOS 10.2) on my new 2016.5 CX-5 GT and Mazda Connect. It often takes a few times to connect, and once connected, I cannot select another station within Pandora. Also, I get connectivity losses almost everytime after 10-20 minutes of use, and that the only way to recover is to put the phone in airplane mode on and off again, then it will reconnect. I'm constantly having to grant the phone permission to connect with Mazda Connect (Pandora) as well. In addition, if I'm using Pandora, then switch audio sources to XM or AM, or FM, etc, then I can't reconnect to Pandora 80% of the time.
I recently used my older android phone (Galaxy Note Edge), and the Mazda Connect system, including Pandora, worked flawless...it was absolutely perfect. Pandora was fast, I was able to select stations within Pandora, and selected different audio sources, and then back to Pandora with no issues. I had no drop outs either...none what so ever. The entire Mazda Connect system worked perfectly.
Whats interesting is that I also have similar problems with my Prius and Toyota's Entune app...it's very unreliable with my iPhone but works perfect on my android phone.
Has anyone else seen this between iOS vs android? I've checked all the permissions and security features on the iPhone, but nothing stands out as why bluetooth/connectivity is so unreliable with my CX-5 and Prius when using the iPhone, yet android works fine on both cars. I'm running version 55.00.753 NA N on my Mazda Connect system.
