Interior mood lighting
DeluxePromo
Cx-5
More photos to come, the lights come with a remote that has about 10 diffrent setting including: decrease / increase brightness, fade diffrent colors that is adjustable, jump to music (works better if you have a subwoofer), and about a couple colors to choose from (will get photo of remote)
Looks Kool [emoji41], I would have to see it live, to see if it would be disturbing for me while sitting and driving, or is it welcome light only on if the door is open? I use the same remote for 2,50$ from Ali, have you cut the LED stripe from a roll and tape them with 3M or are these already fix moduls. Nice job-I like!!
Regards 101
Sent from my iPad using Tapatalk
During driving if you don't have it too bright during the nighttime it's not bad at all. There are 16 brightness setting so plenty of options. Only thing I had to do is peel the 3m tape and connect everything this. I'll upload pics of how I show bacidly no visible wires.
[/URL][/IMG]
[/URL][/IMG]
This is my welcome light- it is only shining when the the door is open. Next I will work on the ambiente light but with single LED's I think-starting on the middle console. I like your Idea/the effect at the doors very much and I have a lot LED stripe left over, maybe I will try.
Regards 101
[/URL][/IMG]
[/URL][/IMG]
Regards 101
Awsome really like what your did! Thanks for the comment, good luck sir.
Sent from my SM-G930V using Tapatalk
Thanks- same to you[emoji4]
[/URL][/IMG]
[/URL][/IMG]
Regards 101
How did you add those?
The LED stripe is glued with 3M tape on the edge of the plastic cover above the legarea-the LED stripe is connected to a LED color module with remote from Ali for maybe 4$ wich then is connected with wires to the back of the car (driver side) to get the energy from the RBCM. Hope that helps.
Here is a new Idea I got from a friend last weekend!! So cool!
Cheers 101
Cheers 101
Exactly what i want to do. Can u link me etc? How hard and how did you wire it into the door?
It's a shining plastic wire for led use you can get a role 5m or 25m then cut it the length you need. You can decide the color of your led's yourself. You need two-one on each end. The plastic wire is just pressed into the slot of the door and the connection with the wires is hidden behind(inside the door).
The connection to electricity we figure out next time because we want it to shine all the time not only for welcome.
I will let you guys know then!
Cheers 101
