- mazda5 GT 2009
I know KYB struts have been a popular choice for many here. A local mechanic suggested bilstein to me. They are almost the same price online. Has anyone used bilsteins? What would be the better replacement for a mazda 5 2009?
Import Replacement Parts
1. BILSTEIN OEM Shocks & Struts (19-197302)
B4 OE Replacement Twintube Shock Absorber
Boot Included : No
Finish : Black Paint
Internal Design : Twintube
Lower Mount Type : Eye 12.1mm
Position : Rear
Upper Mount Type : Stem
Part number: 19-197302 , Weight: 4.00 lbs , Price: $40.94 x 2 = $81.88
2. BILSTEIN OEM Shocks & Struts (22-112811)
B4 OE Replacement Twintube Strut Assembly
Boot Included : No
Lower Mount Type : Base Cup
Position : Front Left
Part number: 22-112811 , Weight: 9.20 lbs , Price: $90.73 x 1 = $90.73
3. BILSTEIN OEM Shocks & Struts (22-112880)
Boot Included : No
Position : Front Right
Part number: 22-112880 , Weight: 9.25 lbs , Price: $90.73 x 1 = $90.73
Subtotal: $263.34
Shipping: $0.00 UPS ground
TOTAL: $263.34
It comes down to the price and what you want in the end. I can absolutely make a blind bet that any Bilstein will be a better quality and fit than any KYB but in the end $$ talks.Thank you for the info. I think I will be using KYB just to be sure since many here have already proven its quality/ fit for the mazda 5. I am going to do the front first. Does the assembly come with the strut mounts? I read that it is advisable to replace them with the struts. I am already replacing the lower control arms, front sway bar bushings and end links.
On the KYB, what are the part numbers / place to buy? Do you replace the springs or just keep the OEM springs?
Also, if I was wanting to change the lower (upper?) rear control arm to get rid of the camber, what is a good part number / place to buy?
I like the OEM ride but the parts just didn't last, completely shot at 70,000 miles.
Thanks!
