running BAD at about 3000rpm PLEASE HELP
Ok so this weekend i decided to check my timing belt, plugs, clutch line. I took the valve cover off and the plugs out and checked everything. At the same time, i took the sway bar, air intake and battery out to check for leaks on my clutch line because the clutch had been acting funny. So anyways i put the plugs back in, the valve cover back on, the plug boots and wires back, the air intake back on, the battery back in and then the sway bar back on. Took it for a drive and it was running BAD. The idle was really low and a couple times it even died on idle while i was rolling to a stop. The worst part is that when i rev to about 2500rpm to about 3500rpm the engine loses power and sputters, hesitates and shakes the whole car. This happens in any gear at any speed. I have no idea what to do and i probably shouldn't drive it if its runs this bad. I need the car for monday for school so quick replies would be extremely helpful. Thanks.
