I thought Firestone could only offer you Continental CrossContact™ LX20? Now you got Pirelli Scorpion Verde™? (uhm)
Many tire companies will give you new set of tires or money back if you don't like the tires purchased. Discount Tire gives you 30 days.
With quieter Pirelli tires hopefully your Mazda dealer can feel or hear your engine resonance noise at 2300 RPM next Tuesday. But I really doubt what they can do about this unless they found the culprit is a bad wheel bearing (not likely、speed related) or some sort of easier one.
yea, my hopes are low. but I gotta try. its bad enough, if the problem cant be fixed, I gotta sell it. I do a lot of highway driving. Cant listen to that crap as I go along at highway speeds, or as I transition thru 2350rpm. as I am changing speeds and the growl happens, I think to myself as I look to the tach, must be at 2350 again. Sad thing is the mechanics now a days (I am an aircraft mechanic) are lazy and if there is no DTC then there is nothing to fix. I mean I troubleshot the tires (with some help from firestone) for crying out loud! One thing we will do is access history to troubleshoot a problem. first in our fleet, then from the manufacture and also the FAA. If there is a problem with something that there are many of, good chance ya arent the first one to experience it.
the other thing I may have forgot to mention is the noise likes "slight throttle pressure". so on decel, no noise, and in neutral holding rpm at 2350, no noise. straight and level holding speed, noise. and increases intensity on uphill grades. tells me when the engine is twisting on its mounts something is hitting something? just a theory.
its funny you mention wheel bearing because its not that much different of a sound. But is cyclical, you can hear it starting at 2000 rpm, whar whar whar, and as speed (rpm) increases, the "whars" come together in sync, THATS when you can feel it in the stick and its continuous.
I had a honda element with a bad rear bearing, put up with it for 2,000 plus miles. I knew it was one of the rear ones. I troubleshot it to the RR corner by swerving at highway speeds and when I put weight on it, turning hard to the left it would get worse, right would almost make it go away completely. but like you said, its not speed related.
