this is the story, I removed the rear calipers and sanded painted and reinstalled but when I tried to bleed them the bleeder screws broke off because of being rusty (toetap) any ideas besides getting new ones Thks Alex
well i used an extractor but it broke off when I heated the caliper with it in there, had to drill it out ,now I have a hole ,was thinking to thread it then plug and try to bleed from the bolt where the lines attaches to caliper. I will get a new extractor for the other one, hope for the best ,will soak the hell out of it with rust release oil ,maybe heat if need be. Thanks guys ,Hi Paul
You probably don't have to thread and plug the hole.
The bleeder screw seals at the tip so unless you drilled in a good half inch it shouldn't leak.
Test it first to find out.
So in plane language if I have my 2 brake lines disconnected I should bleed the right side and then the left caliper next ,it doesnt say if the car should be started or if the key should be in the on or accessory position
Another tip from recent experience: if you have problems getting a firm pedal when bleeding the rears,
unbolt the calipers and rotate them so that the bleed screws are the highest point of the caliper. I went
nuts for several days trying to get all the air out of mine last time until I did that. Pressure bleeding, vacuum
bleeding, gravity bleeding, helper with the pump&hold method - nothing worked until I rotated the calipers
upwards. Work like gangbusters now!
Thanks tlott01 for that tip will keep it in mind when I get around to bleeding if I ever get the screws sorted out,I tried bleeding them but they still felt soft and had to pump them to stop car so maybe your tip will do the trick.Thanks Natay I will look at the video
