Disable Honk Verification
Nitrous
2016 Mazda CX-5 GT
I have a 2016 Mazda CX-5 GT and just had a remote start installed that runs off the factory remote. It works however I have to press the lock button 3 times for it to start.
The problem is that when I press the lock button once it locks the doors and lights flash (no beep). When I lock the second time the horn honks as a verification that the doors were locked. That causes the horn to honk every time I use the remote start. Is there a way to disable it? I have gone through settings and turned the honk to "off" when I lock the doors but it still honks on the double click.
Any ideas?
Thanks
The dealer had a third-party install mine. With it, I can use the lock-unlock-lock sequence to start it, avoiding that horn beep ;)
Maybe that'll work with yours too?
A third-party installed what? My alarm is already installed but the beep is still there.
I meant I have a third-party remote start, so I don't know if my lock-unlock-lock pattern to start the car will work with other brand remote starts. But it avoids the horn beeping for me without the need to disable the lock confirmation beep.
Any ideas?
Thanks
I don't believe there is a user setting on the display for turning off honk if you press the lock button more than once. But I see your point, you don't want to annoy your neighbors everytime you want to remote start your car. I believe the OEM remote module has a honk trigger wire that sends signal to horns, if you can find that and cut it that should solve your issue.
That's what I was thinking. There must be some wire that leads to it. My alternative thought to that was that maybe if I SSH in through WIFI if I can disable it from in there somehow.
OP did you ever resolve this issue?, i'm on the same boat as you right now and i like to get horn chirp off when i remote start the car!
I remember seeing on one of the settings screens a on/off for beep. Not sure what it relates too though it might be for the fob lock function.
Check the settings screens, see if it could help you.
