2003 trans problem
2003 protege 5
When car is on slight incline and in park the car rolls , trans doesn't hold the car form rolling , anyone can help me here thx Alex
I found this...
Did you ever get your TR switch adjusted??
Sounds like it maybe out again or even broken.
Does your P-brake still work?? Just use that or don't park on hills.
If the cable is accessible, unhook it and see if you can push the linkage into park manually. If you can, cable may be bad or out of adjustment.
Latest posts
