Use an online tire size calculator and enter your current rim and tire size. It will show the outside tire diameter. Now put in 17 for rim instaed of 16. Generally if you go 1 size wider and one size lower profile sidewall you'll end up with same outside diameter. Like 195/60/16 and you want to go with 17" rim then a 205/55/17 or 205/50/17 will end up being very very close to the original outside diameter. The other thing to consider is the offset of the new rim. Too much or too little compared to oem will either have you rubbing on fender arch or strut body. IIRC, the oem rims = +45mm. More will move you towards fender arch, less will move tire towards strut body, again, IIRC. Also think there is a stickied thread with a lot of this info......lemme see if I can find it.
