What is "Pad Sub Set" (oem brake pads) ?? thanks
I don't recall ever seeing anything like this before.
I can't for the life of me figure out what the difference is here between rear pad set and rear pad sub set?
This is on the Jim Ellis Mazda website. Anyone who might be able to shed light on this, much appreciated.
did you ever find this out? I'm also in Lex. When I ordered factory pads, they don't come with the hardware kit. you have to order them separately so that must be what the sub set is referring to
No. When I did all 4 sets I went with Centric again. I just re-used the OEM thin wafer like slides and used a wire brush and brake kleen and scrubbed the heck out of them until the thin wafer like things were all good. The key to a great job is high temp siliconized grease especially on the caliper pins. I moved to PA. Too bad we didn't have a choice get together in Lexington.
If you are talking about the rear brakes they might be referring to the parking brake shoes that sit inside the rotor.
