Anyone try Max Brakes and Rotors
1st: I don't race or drive aggressively.
I've been using MAX pads and rotors on my last family 4 cars and happy with the result.
Currently have it installed on my Mazda 5 fronts and they work well for the past 10km, I got their "https://www.ebay.com (commissions earned)"
Remember that slotted rotors will have slightly different pedal feel.
thanks for the update. Did you experience any warping or cracking around the drilled holes?
Not yet.
The longest I've had one set on is about 1.5 years before changing the car :)
Since I don't rave and drive ins a mostly flat ground I don't put any serious load on the brakes.
Slotted design was mostly for looks, not need :)
Ygwypf
Rockauto.com has a nice way of categorizing pads/rotors based on their intended use. Tirerack.com has a nice user base and test reviews braking components are car independent. There is a big price gap from bottom to top but the golden rule is YGWYPF. Theres a reason Centric offers multiple product lines. Btw, if you shop Centrics bottom feeder product line, you can get the full front set for less than the Max kit but it is not slotted/x-drill rotors. Invest in the best pads you can afford based on you driving needs/wants. Any gains in stopping power can be the difference between avoiding or minor fender bender vs. serve accident/injury.
http://www.centricparts.com/index.php?option=com_content&view=article&id=149&Itemid=224
I have the Max brakes right now and am unfortunately dealing with a lot of rattling (in the rear). Might be due to an improper installation.
Latest posts
