SoulArmored CX-5 Build
ok ignore me Chris and Paris as I read your build thread. Seems the H&R are really a good improvement. Thanks for providing the links and input.
Paris1 - Thanks. How is the ride of the H&R springs? The drop does not look too aggressive but just enough.
IMO the drop is perfect. The car just looks "planted" and the fact that the H&Rs level the car (1/2" more drop in the rear than the front to offset the factory "tail high" attitude) is a real plus. The ride is stiffer and takes some getting used to, but it's not horrendous like it would be with a bigger (Corksport) drop.
Body roll is reduced too.
Thanks Paris1. Did you have to get a camber kit? Is there any uneven tire wear as a result of the drop? thanks.
Absolutely, though others here will probably disagree. You need to be able to adjust out the excess negative camber both front and rear or you will get inner shoulder wear at both ends.
