Sorry if I've overlooked this but,
Dm22508
02 protege5
I have most if the msp turbo setup for my p5. I have awr oil pan and I know where to run the lines for my oil. Im having issue findin what the best option is for running water lines. I have the return elbow on my buy list but I don't know where to source it from. I'd like to have several options too if you guys are just loaded with sweet advice.
Just to clarify I need to know where to get the water for my turbo from. Not where to get the part.
I know some people run water lines from the driver's side of the engine on the water block. Remove the lines where the lines connect to the throttle body and connect the lines at the water block and the nipple on the metal line. The throttle body can be bypassed, it does not need coolant warming it up, especially in Texas and it's a popular mod.
The hole on the back of the block is m12x1.5. I'm doing -4 an hoses for my coolant feed and return. The return goes to where the throttle body is fed from on the water neck.
Latest posts
