In Memory of Member 1338
Results 1 to 4 of 4
Thread: Someone with Mazda Knowledge Help!
  1. #1
    Registered Member
    2009 Mazda speed 3 GT Turbo
    Join Date
    Nov 2016
    Location
    Wilmington NC
    Posts
    1
    So last night I traded my 2004 f150 for a 2009 Mazda speed 3 with only 66k miles. It is my first manual car so me and my buddy were practicing on some back roads. He had some trouble going into first after a stop sign so he stalled out like three times.. after he finally got it I started to smell the expensive burnt clutch smell. About a mile down the road we stopped at a gas station (car appeared fine, was downshifting fine. When I tried to leave the gas station the car would not get out of nuetral( was able to move around just not into a gear) I checked brake fluid. My mechanic doesn't have time to look at it today and I'm scared I might have to fix my clutch after having the car for 30 minutes? #brokecollegekid
    What do you guys think? Slave cylinder? Transmission? Fluid leak?
  2. #2
    Registered Member
    Join Date
    Apr 2007
    Location
    Cincinnati, Ohio
    Posts
    62
    Slave cylinder. Turn the car off and put the car into 1st and then start it. If it starts without buckling then it might be something other than the slave cylinder. If it buckles then the slave cylinder needs to be bled.
  3. #3
    Speed3 & TWO Hemis MikeHTally's Avatar
    2008.5 Speed3, 2006 Chrysler 300C, 2003 Ram 1500
    Join Date
    May 2008
    Location
    N. Florida
    Posts
    2,102
    If it's in gear, it won't try to start with the clutch out.
    2008 1/2 CWP GT
    ______________
    Wolo Air Horn
    Cobb SRI/Forge BPV
    15% tint/Vent Shades
    Center Brake Light Flasher
    Redline Tuning Hood Springs
    Cobb RSB/CorkSport MM inserts
    Spin-on filter conversion/Quick Oil Drain Valve
    RX-8 wheels/Painted Calipers/Continental Extreme Contact DWS
  4. #4
    Registered Member
    Join Date
    Mar 2019
    Location
    Mexico
    Posts
    1
    I got a porbelm I got a script and installed it But it didnt work and I had to delete all the script files I fear i mite have delete a Main file for X2 So i reinstalled it it didnt work So i uninstalled it and then delete the Dirtectory And installed it again And it still dont work. The promelms is I Start it up and it Just stays blank Could someone hlpe me plzs ty
    REXROTH INDRAMAT TDM-1.2-30-300-W0 PROGRAM MODULE, MOD1/0X040-007 source
Similar Threads
  1. Need your guys knowledge please help
    By MSP_2003.5 in forum Mazdaspeed Protege
    Last Post: 06-22-2012, 01:23 PM
  2. anyone with dodge knowledge?
    By bgibb68 in forum Lounge
    Last Post: 04-01-2011, 09:00 AM
  3. Anyone with knowledge on early 80's 626's
    By early626 in forum Other Mazdas
    Last Post: 02-16-2007, 12:32 AM
  4. Geography knowledge...
    By MSP#735 in forum Lounge
    Last Post: 05-02-2006, 08:47 PM
  5. Anyone have knowledge of Giga MP3?
    By Matthew in forum Mazda How-To
    Last Post: 09-04-2005, 01:00 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
