Hello I have a 2008 Mazda CX-9 and the blower fan is moving incredibly slow, after the AC Drain got clogged, and the unit filled with water.
I successfully unclogged the drain, and the fan spins, but it is not fast enough to defrost the windows.
The fan also sounds a bit like a record player scratching. I shot the video below from the filter replacement door, with the fan set to max speed to demonstrate. (After taking the video I noticed the debris in the fan, and have removed it and get the exact same results).
https://www.youtube.com/watch?v=RH4YGYHApfo
At this point I suspect that I either need to replace the motor, or the motor resistor, but am hoping for advice as to which one (or both) before ordering parts.
Thanks in advance!
Thanks in advance!
