Hi all.
Found this procedure in the service manual today.
May be helpful since I've seen people ask this question during my lurking habits.
EDIT * Just saw this was already posted in the How-to section*
This entire procedure must be completed in 23 seconds otherwise you have to restart by performing a key cycle. (OFF - ON)
I assume no legal consequences from enabling or disabling DRLs or following this procedure. Enjoy.
- Apply Parking brake
- Turn ignition to ON. ENGINE OFF so all dash lights come on.
- Make sure headlight switch is to the OFF position, also make sure Hazards are off(duh)
- Depress brake pedal the entire procedure. Just firm enough to keep brake lights on.
- Within 2 seconds of pushing brake pedal turn the headlight switch from OFF to parking lights aka TNS(Turn and signal) 5 times remaining in the OFF position.
- Within 2 seconds of Off-TNS 5x - Turn on the hazards switch 5 times ending with hazards off.
- Within 2 seconds turn the headlight switch from OFF to parking lights aka TNS(Turn and signal) 5 times remaining in the OFF position.
