Coil on plug Upgrade
You could do the 1.8L coil conversion. It puts the coils in front of the motor instead of on top. It keeps them cooler.
Yeah... Mounting the coil 6" from the exhaust manifold will cool it down...
1.8 conversion or the Miata Becker performance coils.
IMO the 1.8 coils are slightly more pleasing to the eye, but not worth the cost of swapping for no change at all.
My 1.8 coils stay nice and cool. They are mounted behind the motor on the passenger side of the intake manifold.
Sent from my SM-G900T using Tapatalk
Really? So you've taken thermal readings?
Well, no. Haha, but with the weather stripping on my wiper cowl removed, and with the coil placement so close to that fairly large gap between the hood and cowl, and the use of a plastic spacer between the manifold and coil bracket mounting points to help combat heat transfer. I can say it's probably about as good as one could realistically hope for.
Does anyone have the part number for Miata Becker performance coils.
It would be whatever coils look the same as the stock FSDE coils, probably 99-05 Miata coils.
