I appreciate any help on this.
To clarify, this is an '03 Mazda Protege. The car overheated and some smoke came from under the hood. I checked it out and my coolant from the reservoir had shot out and was empty. Under the radiator cap (I waited before checking this) there was chunky white precipitate around the gasket (the cap is fine and seals well).
Anyways, I drained the coolant and it was a darker, murky green. I drained the oil and the oil looked fine. I recently changed the transmission oil and the dipstick appeared still bright red and no green.
I'm assuming no transfer occurred from the coolant, into the block, since there was no separation in the oil. This is why I'm not sure if it's the gasket or something else. I do understand that the pressure of the oil will be higher than that of the coolant, so that is likely why the coolant is darker now.
Additionally, I checked my reader and got code P0117, which is likely just due to the coolant having gotten too low. Also, I changed the coolant last year, so it shouldn't be bad, unless two coolants mixed and reacted somehow.
