S smetzger 03 P5 (x2), 09 Miata, 07 Mazda3, 13 Fit, 09 Ody Sep 30, 2016 #1 I am going to change the brake fluid out. How much brake fluid does a P5 take? Thanks...
M MrGiggles : Protege5 Sep 30, 2016 #2 Depends on how you want to change it. If just sucking out the reservoir, a pint will do. If flushing through the bleeders, I would just buy a gallon. Flush until fluid is clean.
H hpmaxim Member : 2003 Mazda Protege5 Oct 10, 2016 #3 My usual assumption is you need a quart/liter to adequately change the fluid, and its best to have a second one handy just in case things go wrong. A gallon seems really excessive.
