CX-5 OEM Hitch and Wiring cheap
OEM Mazda CX-5 Hitch/Harness removed from 2015 CX-5 when new. What you see is what you get . All wiring, taps and control box included. Also included is the tow bar insert, and a pin. It did not come with a ball. The wires simply use quick connect wire taps. Fishing wire (4) included for installing the bolts. Shims also included (unused on my car). Mazda hitch cover (under tape).
Install instructions:
Harness Install: http://lib.store.yahoo.net/lib/yhst-24809172479195/cx5trailerhitchharness.pdf
Hitch Install: http://lib.store.yahoo.net/lib/yhst-24809172479195/cx5trailerhitch.pdf
