- 2016 CX-5
For those with new cars right off the lot, just giving you a heads up so you don't worry like I did.
I have OCD and everything needs to be perfect (confused).
I make sure everything works right, otherwise I take it back to the dealer and make them fix it.
Anyways, I check my on board diagnostics whenever I buy a new car to make sure everything is in tip top shape,
low and behold the stupid O2 sensor was incomplete.
Called service and they said to keep driving until it sets, anyway, I kept driving and checking but stupid sensor wouldn't set until today ! after I drove over 1000 miles, there must be a pre-programmed setting or something that the car must be over 1000 miles before it sets, anyways just letting you guys know if you come across this......the O2 sensor will set eventually if you drive long enough.
Also, make sure you do a OBD scan before you take it in for emissions testing.
