1988 323 Station Wagon, KLG4 swap build
Damkid
I recently purchased myself a 1988 323 Wagon, it has been mechanically converted to a GT with the rear disk brakes, sway bars, and of course the B6T
The plan for it is to get it running and plated with the B6T then later I'll pull it out and swap in a KLG4 with a turbo, 5 lug conversion and get it riding nice and low
It was in the beginning stages of being parted out so it didn't run when I picked it up but was told it shouldn't take too much work to get fired back up again
Here's a few pics from when I picked it up
And a bunch of spare parts to go with it
It also had 4 garbage tires on it which can somewhat be seen in this pic
Before I started putting a face back on it I wanted to test fit my festiva ATH front bumper on it, it fits beautifully if I choose to use it :)
After a set of tires I was able to roll it out of the garage for a quick photo shoot and to clean up the garage before I get started on fixing it up
My collection of spare parts
First disgnoses showed it has spark but no fuel pressure, so digging further I found out that the fuel pump was dead
So it's a perfect time for an upgrade with a walbro 255lph pump
Along with a new sending unit and gas tank
The old, beat gas tank with the remains of a mouse nest that was on top of the tank
New tank ready to go in
But after getting fuel pressure to the fuel rail, it still won't fire up, checking things out I found out it lost spark..... Ugh
So I didn't bother putting much effort into getting the B6T running since I wanted a KLG4 in there anyway, so I picked up my donor cat
A 2000 626 with a 5 speed
The goods
And it's almost ready to come out
KLG4 is out
Pulled the B6T out
Since I've worked on KL's in tight engine bays before, I counted on having clearance issues with the KLG4 intake/throttle body and master cylinder and since this engine bay has more room in it then my old festiva, I figured if there's enough room to work with, I'll move the engine forward to clear the MC so it was time for a test fit so I can see exactly what I'm working with
And like I anticipated the throttle linkage interferes with the MC
It looks like I can move the engine forward by 2-1/2 inches and I should still have enough room for the rad
The flex pipe on the Y-pipe needed to be replaced so I figured to also add a V-band clamp to make life easier down the road
Hydraulic clutch conversion using GTX parts
When I did the diff swap in the festive I learned of a thickness difference in the ring/pinion gears between the B6T/BP G series vs the KL G series which does not allow the complete internal gear sets to interchange
And since there was a difference in final drive gear ratios I couldn't simply drop in the 26 diff to the KL trans so I ended up separating ring gears and bolting the KL ring gear to the 26 spline diff..... That proved un-reliable in the long run
For this project I don't want to go with an Mfactory because I didn't like how it felt to drive in the festiva so I started using my brain at what options I have to run an open differential and retain the factory rivets
So knowing KL trans either came with a 4.10 or 4.38 final drive, I got thinking about what 26 spline G series had a 4.10 final drive.... The BP trans..... So tonight I picked one up and got to work
After pulling both transmissions apart, I confirmed they had identical final drive gear ratios
The BP ring gear is not as thick as the KL ring gear but I don't think it will cause a problem since the gear ratios match
I was really happy how that turned out so I started the re-assembly
Today I re-threaded the holes in the block for my intermediate shaft mounting plate I made and installed it
When I bought the 626 the owner said it leaked a lot of oil.... So I ordered new valve cover gaskets which arrived today, so I got those replaced as well
The previous owner of the wagon must have had trouble at some point with the crossmember bolts because the front was welded directly to the lower rad support
So while the engine is out I decided to cut it off so I can make the proper repairs to both the crossmember and the lower rad support
In the process of removing the crossmember I also found the rear bolts were rusted pretty good to the point where I need to basically replace all 4 captive nuts to properly re-attach the crossmember
So today I ground off all the welds on the crossmember, drilled out the mounting holes again (they were full of welds) and re-inforced the ground down areas
Next job is to replace the captive nuts.... ****
I found that some mice once made a home in the cavity for the rear captive nuts
Before I start making motor mounts I wanted to clean up the surface rust from the engine bay, looks pretty ****ty
Then found a rust hole in the strut tower and after having both strut towers on my GT separate, I decided to fix the problem before it becomes a bigger problem
The paint that I picked up doesn't quite match the exterior, but it's close enough lol
Got the mounts made up tonight
I couldn't live with the baby blue, I had to darken it up with some navy blue instead
Also freshened up the engine and got the harness attached so I can start sorting through the harness to get it prepped for splicing into the wagon
Some prep/tidy up work on the harness tonight
And hopefully the last install of the engine
So progress has been steady, parts have come in the mail etc first was a new idler pulley for a PS pump delete which I also trimmed the bracket for a cleaner look
But the belt I ordered was too big so I need to order a shorter one to finish up the install
Also got some new plug wires
Pulled the old shifter linkage out and replaced with a much cleaner set
Axles installed, clutch hydraulic lines installed and bled out
And tonight was fitting the VW rad in the support and making the mounting points etc
Plenty of room left for a fan lol
Next is exhaust work
And the first start up video!!! WOOT!!
https://youtu.be/jbOckjOSQ5E
And now to address the clearance issue between the throttle body and brake fluid reservoir
One coolant pipe welded up, just need to clean up the welds and paint it
I got some more progress to post on here, I got the right sized belt to finish my power steering pump delete setup
Also finished up the rad hoses and heater core hoses
And I got the factory 626 coolant overflow reservoir mounted
And the last clearance issue is solved lol
TEST DRIVE!!!!!
https://youtu.be/KWMPV8dUaFw
Ordered some new fans
Then started working on getting the lighting up front working, the turn signal housings had a lot of corrosion in them so I decided to refresh them with some LED's
The headlights still aren't working but I believe the problem is inside the dash, possibly from mice chewing on the wires but that's the next job to do
But in the meantime, here's a shot I thought looked pretty cool
Found the problem with the headlights, turned out to be a missed connection under the hood, very easy fix lol
But I still knew there was a mouse infestation in the dash so time to pull the interior..... Something I've been dreading......
This first pic didn't turn out the best but you can see the nests inside the vents
Everything out, and I mean everything lol
I spent a couple hours washing doen the firewall, floors, all the ducting including the HVAC unit etc to get rid of any evidence/smell from the mice
The insulation on the firewall had obvious signs where the mice had been so instead of trying to clean it and risk having the smell come back, I decided not to re-install the insulation and hope that the noise level won't increase too much without it
Afterwards I got the HVAC, dash, pedal assembly and steering column re-installed before calling it a day
Today I took the carpet to the car wash and pressure washed it and once it's dry I can finish putting the interior back together
I can almost finally see the finish line to getting this car on the road
I got the interior all back together and it smells so much cleaner in there now.... If I turn on the heater fan I get blasted with the smell of pinesol
Got started on some permanent wiring for the engine harness
Since the battery is now in the back I first picked up a distribution block so I can pull power from the battery cable without running a wire all the way to the back
Then added another smaller distribution block and bolted it to the HVAC so I have an easy spot to power the relays
Then took 2 fuel pump relays and got the wiring prepped for install
Then got the relays bolted down and wired up and ECU wired up permanently
Before I can bolt the ECU in the stock location I need to modify the mounting brackets, I intend to use the stock ECU brackets and use them as a mounting plate for the KLG4 ECU.... Here's a pic to show the differences
Once the mounting brackets are made up I can tuck away the wiring and put the centre console back in place.... But before I do anymore fab work, I needed to see some drive time in this thing, so I took it for a short drive
Then some parts I ordered arrived
And installed...
I also have clear turn signals on the way in the mail to match the new headlight setup
The test drive overall went ok, the engine still has a bad oil leak, it overall feels sluggish but I also know the calipers are sticky so that could be holding it back.... it also pulls to the left but I also know the front drivers wheel bearing is toast and needs replacing
Clear turn signal lenses arrived
This is where the car sits at the moment
Basically the test drive proved how much work the brakes need, so instead of fixing the current setup I'm going to work on gathering parts for a big upgrade
The ultimate goal is to run Speed 6 brakes up front
(drinks)
KUDOS!
Thanks for taking us along for the build!
I love the idea of Mazda-Frankenstein cars... You got some good skills, some patience, and a nice toolbox! Keep up the good work!
(popcorn)
I had hoped to have made more progress on this lately but things haven't really gone to plan
My girlfriend rolled our Ford escape so that put a damper on my little project, she walked away from the crash without a scratch and the escape has survived to see another day
So in the meantime I did a little photoshoot with my daily driver, a rare 88' 323 GT with a factory B6T in it
I still have plenty of things left to finish on the wagon and I will most likely do some small things very soon..... like build a battery box and make an ECU mounting bracket etc..... but the major things.... like a complete brake job, including all 4 calipers..... will have to wait until the new year since I have two little kids that need to be spoiled at Christmas time lol
Wow, hope she's doing ok. That's some scary s***.
Ya man definately is some scary s***, neither one of us has ever been in a crash this bad before, but thankfully she only had some sore muscles for a few days and right back to feeling 100% again
Cars can always be replaced
Sweet cars man and nice work! Makes me miss my old 323 turbo..
Glad to hear nobody got seriously hurt in the crash.
Latest posts
