Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: Autolock not always locking
  1. #1
    Registered Member
    2015 Mazda CX-5 GT w/Tech Liquid Silver
    Join Date
    Sep 2014
    Location
    Bay Area, CA
    Posts
    28
    Does anyone else have an issue with the autolocks not always locking? I park in a gated lot at work and usually in the garage at home, but there have been numerous instances where I get to my car, and the doors are not locked.
    I took it into the dealership to look at, and there was a miscommunication between the service rep and the service tech. The tech put 15 miles on the car to see if the doors were locking when driving around - that was not the issue. I'm reticent to bring it back to them without first finding out if anyone else is experiencing this. (This is the same dealership that took 3 visits before they finally acknowledged the lumbar support had cracked and was clearly crooked, then took another visit before they figured out how to fix it.)
    Either the autolocks are not working all the time, or someone has hacked the keyless system and is unlocking the doors.
  2. #2
    Registered Member
    2016 Mazda6 GT w/Tech; 2014 CX-9 Touring AWD
    Join Date
    Jun 2014
    Location
    Michigan
    Posts
    258
    My 6 fails to auto-lock maybe once out of every 30 times I get out an walk away. I've gotten in the habit of listening for the beep, and failing to hear it, hitting the lock button on the fob in my pocket.
    I'll thank you to kindly see yourself off of my lawn.
  3. #3
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    975
    If you move out of range before the last door is shut and beeped shut it will not lock, you must remain close to the car until the first door closed beep...
  4. #4
    Registered Member
    Mazda CX-5
    Join Date
    Dec 2015
    Location
    Chattavegas
    Posts
    350
    Mine does it. Most often I shut the door and it doesn't beep. Most of those times the fob and my phone are in my pocket and the phone is covering the fob. Sometimes, I can re-shut a door and get the first beep and then it locks when I walk away.
    '06 MX-5 6MT, Custom Sprung Ohlins, Tomei LSD
    '16.5 CX-5 T AWD w/more Soul
    IBA/COG Desmoquattro for pleasure
  5. #5
    Registered Member
    2014 Mazda CX-5 Touring AWD
    Join Date
    Oct 2011
    Location
    San Jose, CA
    Posts
    979
    After discussing this feature with my wife, we agreed to set it to lock only with the black button press.
    This way, we can hear the beep and check that it is really locked by pulling the handle and be sure 100% that the car is indeed locked. We then don't need to worry about "I am not sure if I heard the beep" e.g. because I was distracted nor about "It did beep, but did it actually locked the doors?", because on failure it might just beep without locking anything...
    Pulling the handle is the best assurance to quell our paranoia.
  6. #6
    Registered Member
    2016 CX-5 GT
    Join Date
    Feb 2015
    Location
    New York, United States
    Posts
    142
    Quote Originally Posted by Rarebreed View Post
    This happens when I am walking away and pushing the door behind me to close it. At the moment the door closes I'm about six feet from the door so I'm out have range.
  7. #7
    Registered Member
    16 CX-5 GT AWD w/ Tech
    Join Date
    Feb 2015
    Location
    Baltimore, Maryland
    Posts
    1,116
    This is what I did.
    1. Increase the volume of the beep. You can then hear it better when walking away.
    2. When walking away, not only listen for the beep, but watch for the visual cue of the lights blinking on the headlights.
    Doing these two things, I never miss it not locking. Also, if I'm in an area that is sketchy and not as safe, I always manually lock it. But if I'm just running into stores and what not, the walk away lock works every time for me.
  8. #8
    Registered Member
    2016 CX-5 GT AWD w/Tech
    Join Date
    Jul 2015
    Location
    Vancouver, BC Canada
    Posts
    38
    I had the same issue (occasionally not autolocking). I disabled the feature and now lock manually via the keyfob or button on the door handle.
  9. #9
    Registered Member Anchorman's Avatar
    2018 CX-5 SportNav 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,321
    Having a mobile phone with you - especially near the key or being about a strong electrical field like some garage and shed alarms can generate can also interfere with it.
    The locks are described in detail in the attached pdf and the walk away locking is described well down as the “out of area” locking.
    Attachment 215016
  10. #10
    Registered Member Paul-C's Avatar
    2015 CX-5 GT AWD w/Tech
    Join Date
    Aug 2014
    Location
    Kitchener, ON
    Posts
    74
    This was recently discussed here:
    http://www.mazdas247.com/forum/showthread.php?123856370-Alarm-issues-car-got-broken-into-can-you-help
    I think it happens 1 in 40 times but I can't make it happen so the dealer hasn't done anything. I agree that we should find another way to lock it that is 100% dependable. It's the idea of losing a feature (or turning off a feature) that sucks. I still use autolock but pay attention to the beep.
  11. #11
    Registered Member
    Mazda CX-5
    Join Date
    Apr 2016
    Location
    Mesa, AZ
    Posts
    3
    Having read this and other posts on the same topic, I see four things that keep doors from locking automatically.
    If the rear hatch is not fully closed, they will not lock.
    The key fob is out of range when the last door is shut (passengers getting out after the driver).
    Other electronic devices may be interfering with the signal (usually a bluetooth phone, although mine works).
    Perhaps the battery in the key fob is dead.
    These are known issues and are documented. Rule these out and prove to yourself it is NOT one of these, then you have something to tell the dealer.
  12. #12
    Registered Member
    Join Date
    Sep 2014
    Location
    Bay Area, CA
    Posts
    28
    Thanks for all the responses.
    When the car's in the garage, and the doors are unlocked in the morning, I've double checked that the rear hatch is closed.
    The car is less than 5 feet from the front gate (can't go into the house through the garage), so I'm within range for at least 60 seconds (making sure the garage door closes) after closing all the doors.
    My phone is never in the same pocket as my keys (scratching the screen).
    Battery should be fine since it'll unlock the doors.
  13. #13
    Registered Member
    was 175ps Mazda CX-5 Auto AWD Sport Nav, now 190ps DSG Tiguan 4M
    Join Date
    Oct 2012
    Location
    worksop Great Britain
    Posts
    2,310
    Thanks for this Anchorman
    Quote Originally Posted by Anchorman View Post
    Attachment 215016
  14. #14
    Registered Member
    2016 Mazda CX-5
    Join Date
    Nov 2016
    Location
    California
    Posts
    1
    Red face
    For all of those who are having problems with the Walk Away Locks....
    Mazda is in the process of REPLACING MY CAR ON THE LEMON LAW. You all should be complaining to Mazda NOW so they can fix the problem with their FLAWED system. Every other car manufacture has figured it out.
    If it does not work 100% o the time then they should not sell the system.
    Start complaining now to get your car fixed or replaced. You paid $30+K for your car and EVERYTHING should work as described all of the time, not just part of the time.
    Based on my experience in talking with the Manufacturer Rep here in CA, they do not think they have a problem as they tell me they have had no complaints about it to this point.
    They replaced the sensors on the door handles and it still has a problem. Mine happens about 1 in 10 or less.
    Make sure you get the manufacture rep involved. If you do not, they will not know as everything will be kept at the dealer service dept. If the locks do not work as described, the DEALER should pay you back for what was stolen if you have been broken into. PLAY hard ball it's not your fault.
  15. #15
    Registered Member
    Donated: $5
    2016 Mazda CX5
    Join Date
    Jun 2015
    Location
    Central California
    Posts
    141
    Wow! Your getting your car replaced because the walk away feature doesn't work all the time? You know there's a little button on the remote that works every time... you can hear it lock. Is that really a deal breaker? Can't imagine how you deal with your cable/cell phone company
Similar Threads
  1. Autolock Anti-theft
    By niteviper in forum CX-5 Lounge
    Last Post: 04-06-2016, 05:40 PM
  2. Replies: 13
    Last Post: 01-04-2016, 03:23 PM
  3. Autolock doors?
    By mammut in forum CX-9 Lounge
    Last Post: 12-12-2007, 12:00 PM
  4. Programming autolock
    By montrealer in forum Mazda CX-7
    Last Post: 06-04-2007, 03:57 PM
  5. Autolock really works?
    By Jliao in forum Lounge
    Last Post: 07-08-2003, 03:49 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
