Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 2 of 2
Thread: Mazdaspeed6 compressor not clicking on after new compressor clutch kit
  1. #1
    Registered Member
    2006 Mazdaspeed6
    Join Date
    Oct 2015
    Location
    Orlando
    Posts
    5
    The compressor clutch in my MS6 went bad. The bearing was shot and something caused the actuator coil to basically melt.
    I finally got the new clutch kit installed (new actuator, clutch, pulley wheel, and bearing).
    Now that I've replaced everything I would expect the compressor to click right on but it does not.
    Prior to the clutch failure, the AC was working fine, (blowing ice cold), so I don't suspect the actual compressor or the refrigerant level.
    My hunch is something electrical upstream from the clutch actuator went bad when it melted.
    I've checked the AC fuse located in the passenger compartment and it's fine.
    I also tested the AC relay and it's fine.
    Any ideas? No, I didn't forget to plug in new clutch actuator...
    Thanks!
  2. #2
    Registered Member
    2006 Mazdaspeed6
    Join Date
    Oct 2015
    Location
    Orlando
    Posts
    5
    update:
    I checked continuity from the clutch actuator connector back to the relay and the connection is good.
    With the car running and AC on I just jumpered 12V to the relay socket (AC clutch side) and bingo! cold AC.
    However, when bypassing the relay, shorting the NC and COM connections on the relay socket it doesn't work.
    Why isn't there 12V on the relay? I guess I need to see a wiring diagram. Anybody have it?
    Thanks
Similar Threads
  1. Clicking from AC compressor
    By newUser08 in forum Protege5
    Last Post: 06-13-2015, 07:08 PM
  2. How do you remove AC clutch from compressor?
    By v02maxed in forum Protege5
    Last Post: 08-20-2013, 11:04 PM
  3. AC Compressor Clutch Issue
    By DeCaro in forum Protege5
    Last Post: 03-31-2013, 04:11 PM
  4. A/C Compressor Clutch Clicking
    By lattle in forum Protege5
    Last Post: 07-09-2011, 11:56 PM
  5. Replies: 5
    Last Post: 03-31-2010, 09:07 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
