- 03 Mazda Protege5
Hey there, so I just finished swapping all my cluster bulbs and adding more LED's to swap the color to blue. I put the cluster in several times throughout the process to check hot spots etc, and everything was working. This last time, I installed and spliced the extra LED's into the left plug(white wire, was 12v power) and the ground into the green/red wire in the same plug, purely because it was the easiest to find and the lights worked. But now the three afformentioned gauges stopped working, and I popped 3 codesm each to do with one respective gauge. Is this because of where I powered the LED's, or something else?
Edit: Also something that may be helpful, my ABS light is on now?
