Or are they just going to replace the HYD dampers????
"Insufficient corrosion protective coating was applied to the ends of the external cylinders of the rear hatch/lift gate gas stay dampers (lift supports). If water containing road salt enters, it can cause corrosion. Over time, increased corrosion may eventually cause it to break as the rear hatch or lift gate is opened.
Safety Risk: The rear hatch or lift gate may drop suddenly, and/or the broken parts may hit the customer, causing injury.
REPAIR DESCRIPTION
Dealers will replace the lift support, at no charge to the owner.
