Help:: Enkei wheel for mazda 2 1.5 skyactive
rallycrazy
i just buy mazda 2 1.5 skyactive sedan. I want upgrade wheels. I like Enkei PF01 16" +43 and RPF1 16" +35.
Which's wheel in those fit my car?
Thank you for your help!
Given the current info, we'd need to know the width in order to really know for sure whether or not it fits. I think up to 8" should be fine for the RPF1, and possibly both. I'd be worried about the inside clearance at 8" +43, but I think it'll likely be fine.
Assuming that the OP has a 1.5L SkyActiv Mazda2 sedan, I'm guessing that is the same car as the Toyota / Scion Yaris iA sedan in N.America. For that car, Tire Rack lists an acceptable offset range from 37 - 45, depending on your intended tire size. Assuming a 16x7 (since that's what the RPF1 is), you'd probably want to run something in the 195 - 215 range (for tread width) though.
