Page 1 of 5 123 ... LastLast
Results 1 to 15 of 65
Thread: 2016 CX5 GT Needs new pads
  1. #1
    Registered Member
    K2500 Diesel Suburban
    Join Date
    Apr 2014
    Location
    Connecticut
    Posts
    47
    Looking to order pads for my 2016 CX5 Grand Touring. Called the dealer and $118 for the front set.. WOW. Amazon has them for $58 and list them as OEM K0Y1-33-28ZA-MV from Avondale Mazda. They list as fitting 2013-2016 but I've read on this site that 2016's are different? Anyone know the part number for front 2016 CX5 GT? Also looking to get rears too so if you know the part number please post. Also Anyone know a good online site to purchase pads?
    Thanks
    Steve
  2. #2
    Lover of 5's Robotaz's Avatar
    2009 Mazda5 GT
    Join Date
    Aug 2009
    Location
    Mexington, KY
    Posts
    1,456
    That's amazing. I've never had to replace pads on any car with less than 100K miles in 28 years of driving and having owned probably 20+ vehicles in the family.
    Something sounds terribly wrong.
  3. #3
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    935
    Check out sponsor above Med Center. Others have had rear pads go before fronts...
  4. #4
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,457
    Blog Entries
    8
    I wonder if caliper slide pins weren't adequately lubricated? I went through and did all mine months back. Some were nearly dry and some had grease. A pretty easy job to tackle if you already have the tires off for a rotation.
    PATREON SUPPORTER
    NB1 Navigation Updates (1005 NEW-2/2018) / Why Mazda moly oil? - Mazda TSBs / Mazda owners manuals / SkyActiv Oil Analysis Thread
    Current Vehicles:
    '15 CX-5 GT 2.5L w/tech package & i-ACTIV AWD - Liquid Silver Metallic (04/2014 build-07/2014 delivery) - 41K Miles
    '12 Lexus GX 460 Premium (Toyota Land Cruiser Prado Kakadu 150) BOF / Torsen with ATRAC AWD/MTS/Crawl Control - 47K miles
    '07 Infiniti G35x w/tech (Nissan Skyline V36) / ATTESA E-TS AWD - 94K miles
    '00 Jeep Wrangler 4.0L TJ - 5 speed / NP231 PT Transfer Case - 118K miles
  5. #5
    Registered Member
    Join Date
    Apr 2014
    Location
    Connecticut
    Posts
    47
    I don't know if I need new pads or not. I want to have a set on hand so when I am rotating my tires I have them IF needed. For those that have purchased pads for your 2016 can you share the model numbers?
    Thanks
    I just checked Med Center but they don't list 2016 models??
  6. #6
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,457
    Blog Entries
    8
    Sorry I can't help on part #... other than someone who has had some warranty work and can post part numbers from the work order you may have to call dealer to confirm. I don't recollect many swapping pads yet.
    Unless you have uneven pad wear it is possible to see pad depth through inspection hole on caliper with a small mirror and flashlight.
    Is your brake fluid reservoir level down quite a bit too?
  7. #7
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,457
    Blog Entries
    8
    Here are some OEM pads from Avondale Mazda that claim '13-'16.
    https://www.amazon.com/2013-2016-Maz.../dp/B0118Y7QD0
  8. #8
    Registered Member
    Join Date
    Apr 2014
    Location
    Connecticut
    Posts
    47
    Thanks. Avondale Mazda is where I saw them. Does anyone that owns a 2016 know if those are the latest pads?
  9. #9
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,505
    My 2014 CX5 FWD rear pads are approx. 20% worn at 26,000 miles. As Robotas stated; something is terrible wrong. Check to see if brake fluid level has dropped significantly and do a proper pad thickness measurement. Ed
  10. #10
    Registered Member
    Join Date
    Apr 2014
    Location
    Connecticut
    Posts
    47
    I called Med Center Mazda and was told they changed the pads for 2016 KAYO2648Z Tried googling the part and nothing but overseas companies. I just rotated my tires and plenty of pad left all around after 30K miles. Just like to find the right set to keep on hand. Maybe I'll call the local dealer again and see what they say. Guess there were problems that got corrected in the 2016 models.
  11. #11
    Registered Member
    Donated: $5
    2014 CX-5 GT FWD, 2015 Mazda 3 Touring
    Join Date
    Apr 2013
    Location
    Texas
    Posts
    1,657
    Quote Originally Posted by erhayes View Post
    This is also my experience with pads. Most of my miles are highway so YMMV.
  12. #12
    2009 Mazda5 GT
    Join Date
    Aug 2009
    Location
    Mexington, KY
    Posts
    1,456
    Keep in mind that almost all brake service centers give a "lifetime warranty" on the pads. There's a reason they're so confident. It's because they last forever.
    Since my earlier post I was thinking about my F150 with 312,000 miles on it. I replaced the pads after some very heavy towing in 1998 at 180,000 miles. The pads are still fine 18 years and 132,000 miles later. They have at least half the pad left.
  13. #13
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,457
    Blog Entries
    8
    Quote Originally Posted by Robotaz View Post
    That is some serious great wear!!!! I've never gotten beyond 100K miles myself... that being on my old beater '96 Explorer (5.0L AWD). I've decided I will never get rid of that vehicle and plan to keep it with the '00 Wrangler at my cabin full time in a year or so. Worth so much more to me in utility than I could ever purchase as new today.
  14. #14
    Registered Member
    Join Date
    May 2013
    Location
    Portland
    Posts
    2
    I just replaced the rear pads on my 2014 with 46k miles. Nothing was terribly wrong, I did find it odd that the rears went before the fronts but that could be explained by my driving or towing my kayak trailer around.
  15. #15
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,536
    Get the stoptech pads, they are about the same price and thicker and no noise too. I replaced my front/rear with stoptech preferred (basic) rotors and posi quiet pads
Similar Threads
  1. 2016 - Soft Brakes - Better Pads?
    By Lbear in forum CX-5 Lounge
    Last Post: 02-22-2017, 06:21 PM
  2. 2016.5 v. 2016 Grand Touring
    By RobDMB in forum CX-5 Lounge
    Last Post: 01-25-2016, 01:29 AM
  3. Replies: 83
    Last Post: 01-15-2016, 01:21 AM
  4. 2016 CX-5 AWD or FWD vs. 2016 Mazda3 5-door s GT
    By olliedawg in forum CX-5 Lounge
    Last Post: 01-13-2016, 08:12 AM
  5. Axxis Pads FS - Metal Master - High Performance pads
    By joesturbo in forum Mazda Protege
    Last Post: 03-04-2006, 02:01 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
