In Memory of Member 1338
Results 1 to 3 of 3
Thread: How To: Install Redline Goods leather armrest cover on OE armrest 0000-8D-P10
  1. #1
    Registered Member
    2014 Mazda 2 GX
    Join Date
    May 2016
    Location
    Nova Scotia, Canada
    Posts
    19
    This leather armrest cover by Redline Goods is designed to fit the OE Accessory armrest 0000-8D-P10 for 2011-2014 Mazda 2.
    I'll post a link to the product once it's listed on their website.
    Tools required:
    • Philips screwdriver
    • Philips screwdriver bit or stubby screwdriver
    • Leather safe glue
    1. Remove the OEM armrest pad by opening the lid and removing the 5 screws that hold it in place. In order to remove the bottom 2 screws, the lid needs to be partially closed - this is where the stubby screwdriver or bit comes into play. The screws are not tight, but the bottom two require some patience.
    2. Line up the new leather cover directly over the OEM pad, ensuring that the overlap at the front lines up with the overlap of the original vinyl cover.
    3. Once you're satisfied with how it's lined up, you can begin gluing (only the front) applying glue directly to the underside of the armrest pad on the overlap of the OEM vinyl cover, the pressing the new leather cover into place.
    4. Once the glue has had time to set, pull the leather cover tight towards the rear, and once properly lined up, glue at the rear using the same method.
    5. Repeat with each side, one at a time, ensuring that the cover is pulled tight as you go. Pay close attention to the two rear corners, ensuring that you fold them in a way that will not interfere with the screw holes.
    6. Reinstall the pad on the armrest lid using the same 5 screws.
  2. #2
    Registered Member
    2012 Mazda 2 Touring SG 5MT
    Join Date
    Apr 2012
    Location
    Gainesville, GA
    Posts
    1,425
    Thanks! Hopefully I'll get around to this at some point.
    His - 2012 Mazda2 Spirited Green Touring 5MT
    Hers - 2007 Nissan Frontier Nismo CC 4x4
    Track/Fun - 1999 mostly green miata
  3. #3
    Registered Member
    Join Date
    Jul 2019
    Posts
    2
    Among the products mentioned on the list, which one is the best? https://11must.com/best-glue-for-leather/
Similar Threads
  1. Redline Goods leather armrest cover
    By murch in forum Mazda2 Lounge
    Last Post: 08-02-2016, 12:32 PM
  2. CX-5 Armrest Cover (GT w / Black Leather)
    By Chris_Top_Her in forum CX-5 Accessories & Appearance
    Last Post: 12-24-2014, 09:55 AM
  3. Replies: 1
    Last Post: 03-25-2014, 10:42 AM
  4. RedlineGoods 04-09 Leather armrest cover
    By hectik1 in forum Completed Transactions
    Last Post: 08-27-2010, 02:35 PM
  5. Redline leather armrest cover MS3 or M3
    By LuckyKelleyK in forum Completed Transactions
    Last Post: 08-11-2010, 07:50 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
