In Memory of Member 1338
Page 3 of 18 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 262
Thread: the p5nugget
  1. #31
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Some guys broke 3/4" ratchet handles. Others had a 6 foot extender on a breaker bar and had to jump on it.
  2. #32
    Registered Member
    lolmsp lolms3
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,349
    everything is back on. took a drive and it's so quiet now. no more airplane like drone at high speeds. wife called the p5 airplane mode for a while.
    Quote Originally Posted by MeAndMyPenguin View Post
    You got lucky. Had to drill the nut in half for mine. Went to 3 shops with air impact guns and none of them broke it loose lol
    bad luck! lol. i did have an axle seize to my hub on my msp. that wasn't fun.
    Quote Originally Posted by pcb View Post
    sheesh. never again. i'll stick to the borrowed impact.
  3. #33
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Quote Originally Posted by 323 View Post
    .... i did have an axle seize to my hub on my msp. that wasn't fun...
    Some mechanics include the price of a new axle in their original quote.
    They don't even bother trying to take things apart. They just cut the axle, remove the knuckle and take the whole works to the machine shop.
  4. #34
    Registered Member
    lolmsp lolms3
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,349
    if being time efficient is their goal, it makes sense.
    the P0401 "EGR Flow Insufficient" keeps coming up for a couple days every 3 weeks or so. guess i should take care of this now
  5. #35
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    It's not just time, it turns into a safety issue too.
    Jackie chan could have been killed when he did his bearings. (if the piece of shrapnel would have hit him in the head)
    First you've got your seized axle nut... Then the seized axle in the hub... Then the seized bearing in the knuckle.
    One guy couldn't press out the bearing with a 12 ton press.
    Anyway... You might want to consider the "Canadian" EGR with the coolant lines if cleaning your EGR is becoming a yearly/ monthly activity.
    The guys that have installed them say they haven't had a problem with them since.
  6. #36
    Registered Member
    lolmsp lolms3
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,349
    i haven't cleaned the egr at all since owning the car so that will be a chore that i do soon. does the metal gasket have to be replaced everytime the egr is reinstalled?
  7. #37
    Team Pro5 Jackie chan's Avatar
    Pro5
    Join Date
    Mar 2011
    Location
    Seattle, WA
    Posts
    1,927
    I don't usually replace it.
  8. #38
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    i haven't cleaned the egr at all since owning the car so that will be a chore that i do soon....
    I've never cleaned my EGR either,.. and I live in Canada,.. Which is where the "Canadian" version of the EGR was invented for.
    I have the original EGR still installed and working fine.
    There's all kinds of codes covering EGR problems and if my car stumbles at idle I'll start with Seafoam, then clean the IAC then the EGR...
    If It ain't broke don't fixer...
  9. #39
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,420
    Ooops... Didn't read the thread...
    Yea,.. You got work to do.
    Here's the instructions for the routing if you decide to go "Canadian"...,
  10. #40
    Registered Member
    lolmsp lolms3
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,349
    RIP roof rack/rail covers. GG. They're super brittle
  11. #41
    Registered Member Ban-Hammer's Avatar
    Mazda Protege5
    Join Date
    Oct 2016
    Location
    OR
    Posts
    46
    Story of my life. Thank god for Gorilla Glue!
  12. #42
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,125
    I've tried to remove them at the junkyard before and they always break. If I end up with another P5 I plan to completely remove the racks.
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14-SOLD
    2003.5 Titanium Mazdaspeed Protege #32 Purchased 3/23/19
    2003.5 Laser Blue Protege5 Purchased 6/17/17 SOLD
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  13. #43
    Damian Dpwhitehead1's Avatar
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Owings Mills, Maryland
    Posts
    9,368
    I have this man covered! Basically a new set at my house
    Be happy!
  14. #44
    Registered Member
    lolmsp lolms3
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,349
    oil change @ 193,500
  15. #45
    Registered Member
    lolmsp lolms3
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,349
    swapped out passenger motor mount with a hand me down one with inserts. woohoo. old one was busted of course. i still need to take care of the last 3 to do items on the list!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
