Hello. Starting a thread to keep track of maintenance, to do lists, and post photos. Picked up this P5 as a daily/backup car in November 2015 to replace a civic hatchback. Since I have a bunch of protege parts laying around, a p5 made sense. For now at least. The wife uses the p5 when her car is down for repair too so that's pretty cool.
Picked up this car with 185k on it. The engine was dusty but everything was intact. Most of the issues on the car were cosmetic. Driver fender appeared matte and dented up from a slight fender bender. Driver side sideskirt was hanging off. Corner of the front bumper right under the fog light was punched in. Headlights were cloudy and fog lights were missing. Interior was pretty neglected and missing rear speakers.
Maintenance:
Goodies:
To do list in no particular order:
SOLD at 205k miles to the lucky lady named Damian (yippy)
Maintenance:
- 186,000 miles: installed deeza lower control arms
- 191,000 miles: timing belt, water pump, accessory belts, thermostat
- 195,500 miles: transmission gear oil changed
- 197,730 miles: replaced rear passenger caliper, readjusted ebrake, bled brakes
- 199,915 miles: replaced bad primary cat with manzo header. installed used primary (125k) and secondary o2 (59k) sensors
- 199,950 miles: installed beck/arnley outer tie rods
- 201,600 miles: new front struts
- 202,700 miles: oil change
- 203,800 miles: all within 1 tank of gas, new strut mounts & bearings, driver side inner tie rod, driver side LCA, driver side hub & wheel bearing
- 204,757 miles: last oil change
Goodies:
- OEM MSP headlights w/ H4 LEDs
- Yellow fog overlays
- MP3 short shifter & shift knob
- MP3 ECU (borrowed from Gabe710)
- Tein S-Tech springs
- Manzo Header
- DIY intake
- Generic antenna from eBay
- MSP rear sway bar with CR3 rear sway bar brackets
- paint rusty wiper arms
- paint rear wing? clear coat is peeling
- clean and install interior carpet
