HELP: Clutch Slave Cylinder
cukaracha
Mazda 2 Sport
I ordered an OEM replacement clutch slave cylinder. When I connected the fluid hose to it, it kept leaking even after I snapped in the metal ring. I tried with the old slave cylinder and there isn't any leaks when I connect the fluid hose. What am I doing wrong? Did I get a faulty replacement part?
Are you seating the hose end in deep enough ? does it go into the body of the cylinder the same amount as the old cylinder ?
Latest posts
