2016 CX-5 GT with the infotainment system, we've had it for 1 year & have almost 20k miles on it.
Factory setting for oil change was by mileage. At the first oil change (~5000 miles) at the dealer, I reset the oil change monitor before leaving the dealership parking lot & then set the system to Flexible so that it calculated based on speed, type of driving ,etc. A couple months after the oil change, the dash started showing "Change Oil", but when I checked the Maintenance in the infotainment system, it showed we still had 70% oil life left. I ended up changing the oil for the 2nd time at 11k miles, & again made sure I reset the monitor. The next week, the "Change Oil" notification came up on the dash.
Took it to the dealer, & they changed to Mileage-based, turned the mileage interval down to 0, then back to Flexible & reset the system. The car was fine for a few months, but came on again with 60% oil life shown. The mileage was at about 18k (~7k miles on the oil), so I changed the oil & reset the system again.
And.....a few days later, "Change Oil" came up again. This time, I changed to mileage interval, turned the interval up to 50k miles, then changed back to Flexible & reset the system.
Has anyone else seen this issue? I expect the Oil Change notification to come up when the oil life is around 20-30%, not 70-80%. Perhaps there is still a mileage interval built into the system so that no matter what the oil life % is, it will trigger at a mileage. But it still doesn't make sense that it comes up after changing the oil & resetting everything.
The dealer says no one has had complaints or issues with this. So I turn to the internet to see if anyone else has issues.
Justin
Justin
