I'd bet that your owners manual can tell you how it works. All kinds of good info in there. Give it a read some time.
Amen!
I am sorry for asking silly questions. I am new to Mazda . So learning new things
I have checked owners manual http://www.mazdausa.com/MusaWeb/musa2/pdf/smartguides/2016_Mazda_CX5_Smart_Start_Guide.pdf
But didn't get proper answer
Watch out when the clutch swings down from under the dashboard!
I see there is option "M" near "D" in gear box ( CX5 Touring )I think "M" stands for manual. I have always used automatic drive option.Could you please tell me how to use "M" option ? is there any advantage of using "M" ? (headbang)
I was wondering, how is the sport mode in the '16 models? I have the '15 which lacks one (but I find the manual mode more than adequate)
Also, what many people can't seem to figure out: the "kickdown switch"
If you never floored your accelerator you won't know of its existence. It's an actual switch located under your accelerator pedal. You can test it out with the car off if you're afraid: when you push the accelerator down mildly all the way, you think you've floored it, but if you push harder, you activate the "kickdown switch".
What it does is when the car is moving, it will downshift as much as possible and unleash full power. It will even downshift when you're in manual mode, which is probably faster than downshifting 1-3 gears manually.
Actually, if I floor it without activating the switch, the car might not even downshift depending on the situation, but when you press the switch, you can be sure the car will make every effort to unleash as much power as it can.
And yes, it requires getting used to the lag of the manual mode - at first I constantly hit the revlimiter while using manual mode, because I shifted too late. Now I subconsciously shift a bit early so it times perfectly to before max RPM.
For those accusing me of driving like a maniac - well, I've never driven an SUV/CUV/crossover/name it whatever that was so much fun. It almost demands being driven hard.
