Hello, tried to power the camera with 12 volts from the reverse light, when i put the car in reverse the radio dont see the camera (think the signal from start up camera is not fast engough) , so if i connect the 12volts at a source withs is powered on startup of the car AND then put it in reverse the camera screen works. Nice i think , BUT when i put it out of reverse gear the screen switch to navi or radio NOT to the sensors screen! The sensors still work (beep beep) but not on the screen. When i start the car with no camera connected the sensor screen works normal.
Has someone a solution for this problem.
Thanks Marc
Thanks Marc
