Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 200
Thread: SkyActiv Oil Analysis Thread
  1. #46
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow SkyActiv Oil Analysis Thread
    Quote Originally Posted by CX5_Pete2 View Post
    I did some reading over the weekend on oils after seeing Mobil 1's new 20K or 1 year OCI capable oil at Walmart the other day (it costs almost $50 for 5 qts!), and I came across this:
    https://www.oronite.com/products/lspi.asp
    It talks about the effects of Low Speed PreIgnition (LSPI) and the type of oil being used.
    In short, for our high compression DI engines, it's best to go with a high quality synthetic oil with high molybdenum (MoS2) content that also uses a detergent low in calcium (Ca).
    (If this information has been mentioned before, I apologize.)
    The Mazda 0W20 with Moly vs the Mobil 1 & 200ml MoS2 shows that the Mazda Moly has high MoS2 content, but has almost double the Ca content of Mobil 1. Makes question whether or not the Mazda w/ Moly is best for our engines?
    I will continue to experiment with Mobil 1 or Pennzoil with the addition of Liqui Moly MoS2.
    Yeah Low Speed Pre-Ignition (LSPI) indeed has been brought up in this oil dilution thread before but we don't mind you keep doing your experiment and reporting the result back:
    2.5L Oil level fluctuation
    Quote Originally Posted by yugrus View Post
    My wife's CX-5 is seeing lots of short trips, and indeed the oil level goes up. Used oil analysis shows fuel dilution, as expected.
    Reading about this I came across the condition that is called Low Speed Pre-Ignition, LSPI. Evidently, this only affects DI engines and is much more detrimental then regular pre-ignition that causes pinging. LSPI can't be detected by the knock sensor, so OEMs are dealing with it by dumping fuel under conditions that MAY cause LSPI, making it impossible to happen. Hence, most of the DI engines have fuel dilution problem, the fuel just burns off during long drives in fully warmed-up engine. No such luck for us short-trippers...
    Quote Originally Posted by madar View Post
    The hole keeps getting deeper and more stuff keeps coming out about this.. Click on the lubrication tab on this link and see what it says about moly oils
  2. #47
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,068
    Been wanting to post this for awhile, this seems the perfect time and place to do so: Here's my vote for Pennzoil Platinum 0w20
    Moly:
    I'm using Pennzoil Platinum 0W20 based on research others did on BITOG forums and other sources. To get straight to the point it uses tri-nuclear Moly which is superior to old school moly. Lower content of tri-nuclear Moly could be used as a substitute of higher amounts of old school moly.
    Base Stock:
    The base stock of PP 0w20 is from natural gas making it a synthetic. I'm assuming its a group 4 oil. Research of Mazda w/moly suggest its base stock may be a really good Group 3 oil. Plus PP's base stock should have less impurities than other group 4 oils.
    Cleaners/Additives:
    PP has cleaners and detergents which has caught the attention of long time Mobil1 user turned converts implying the PP 0w20 made their engines sound quieter after some time. Since PP's parent company is Shell and I primarily use Shell I figure hey, I'm using oil and gas both with additives made by the same company.
    NOACK:
    Folks posted 10.1% which is well below 13% for Dexos max limits. Seen other post 8.9%.
  3. #48
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,409
    Quote Originally Posted by CX-5um View Post
    Moly:
    Base Stock:
    Cleaners/Additives:
    NOACK:
    I'm a big fan of PP. Haved used it quite a bit and it seems to wear the best, that is getting the best oil mileage out of it. Also have used the Mazda Moly quite a bit, but there' not much out there about additive packages other than being loaded with moly.
  4. #49
    Registered Member
    CX5
    Join Date
    Sep 2016
    Location
    CA, USA
    Posts
    8
    Quote Originally Posted by yrwei52 View Post
    Thanks, good info in this thread.
  5. #50
    Registered Member
    Donated: $15
    Join Date
    Mar 2013
    Location
    Posts
    1,409
    Has anyone considered doing a UOA of their trans fluid? There's lots of back and forth on this forum about how long trans fluid is supposed to last so it might be interesting to get some backup. Here's a Honda example:
    http://www.odyclub.com/forums/24-199...ion-fluid.html
  6. #51
    Registered Member
    Cx5
    Join Date
    Mar 2017
    Location
    Michigan
    Posts
    24
    Has anybody done a UOA using amsoil 0w-20? I use amsoil in my wife's wrangler and my Shelby gt500. I just bought a 2017 cx5 and debating what to put in after break in miles are completed.
    Sent from my iPhone using Tapatalk
  7. #52
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow
    Quote Originally Posted by docs03 View Post
    Keep your moly-rich factory filled oil as long as you can! Make sure to use Mazda recommended "Flexible" maintenance schedule for oil change!
  8. #53
    Registered Member Seminole's Avatar
    2014 CX-5 GT w/ Tech
    Join Date
    Aug 2007
    Location
    USA
    Posts
    554
    I had this done before I knew I was trading in my 14 for a 17. Hopefully the 17 engine is as solid as my 14 was over the 75k miles I had it.
    Current: 2017 CX-5 GT Machine Gray
    Past: 2014 CX-5 GT w/Tech Crystal White
    Hardwired V1 - (click here for instructions: http://www.mazdas247.com/forum/showt...-a-Valentine-1)
  9. #54
    Registered Member
    2016 Mazda CX-5 Grand Touring AWD
    Join Date
    Jul 2015
    Location
    East Greenwich, RI
    Posts
    108
    Quote Originally Posted by Seminole View Post
    Image Snipped
    Wow, nice UOA! What oil and filter was this if you don't mind me asking? Clearly not MMO judging from the Moly number.
  10. #55
    Join Date
    Aug 2007
    Location
    USA
    Posts
    554
    Quote Originally Posted by Speedie95 View Post
    Regular Castrol 0w20 with a Mazda filter. I get the oil changes done at the dealer and they use Castrol.
  11. #56
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,871
    Thanks for that.
    My dealer had also switched from using Mazda Moly to Castrol.
    Had wondered if the Castrol worked as well. So far I have had no complaints, and it looks like you are getting some good reports. Makes me feel better
  12. #57
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,795
    Would be nice to see more UOA and also if anyone is running a 5w30 oil. Ed
  13. #58
    Registered Member
    2017 CX-5 GT AWD
    Join Date
    Dec 2017
    Location
    OH
    Posts
    850
    anyone do uoa with a dealer oil change? what is the easiest way to get a sample?
  14. #59
    Registered Member RepeatMazda's Avatar
    '16.5 CX-5 Touring AWD
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Hey everyone! First post here, though I have checked in and read a few threads on occasion. I've been on BITOG for a long time now but never had a need to do a UOA. With the purchase of my second CX-5 (First one was a '14 GT) and the OLM option that was given on the '16.5 model year, I decided it was the perfect opportunity. Based on my driving it seems optimistic. I've never had it get below 50%. Seems to me that the cold weather we experience here definitely is a cause for fuel dilution in the winter. I've got about 1k miles left on this OCI and I suspect to see similar results as UOA #2. I'll be dropping down to 1 year or 8k miles on the next two OCI and see if that improves the dilution results. Let me know if you have any questions!
    0 - 1,169 - Factory Fill
    1,169 - 10,120 - Mag1 0w20
    10,120 - 19,949 - Mobil Super Syn 0w20
    19,949 - 30,031 - Mobil 1 EP 0w20
    30,031 - Present - SynPower 0w20
  15. #60
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Quote Originally Posted by RepeatMazda View Post
    So we can safely assume Mobil Super Syn 0w20 is the worst among oils you’d used preventing fuel dilution ⋯
    Thanks for posting!
Similar Threads
  1. Used oil analysis
    By Seminole in forum CX-5 Engine & Transmission
    Last Post: 04-24-2016, 09:49 AM
  2. My CX-5 UOA (Used Oil Analysis)
    By JTNY in forum CX-5 Engine & Transmission
    Last Post: 01-19-2014, 12:20 AM
  3. Replies: 20
    Last Post: 11-17-2012, 02:29 PM
  4. My Oil Analysis Results
    By Jasnall in forum Mazdaspeed3
    Last Post: 10-27-2009, 07:24 PM
  5. Oil analysis..who,what,where,when, and how?
    By Mike R in forum Mazda Protege
    Last Post: 04-24-2004, 01:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
